Old 12-20-2009, 05:26 PM   #21 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Tygen1 View Post
How much boost are you running at these low load crusing rpm's while lean burning? You'd think a turbo big enough to make 450hp at 30psi wouldn't do much at under 2000 rpm...Is the Turbo just helping to reduce pumping loss in these conditions?
Not much boost at my low load level cruising rpm's. But it is helping a ton as far as pumping losses. I'm running a Holset 351 diesel turbo.
Pressure Gradient Force
The Positive Side of the Number Line
Old 12-21-2009, 01:59 AM   #22 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Bot...
Old 12-21-2009, 02:38 AM   #23 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
What has been your limit on how lean you can get? I understand that once the mix is lean enough it does not really support combustion and that it drops off steep (both on the lean and rich sides) How even is the mix across all 4 cylinders?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 12-21-2009, 09:09 AM   #24 (permalink)
Have you folks studied engines like the Revetec?
Revetec Homepage revetec.com
Or, new rotary designs like this one?
Green Car Congress: UK LowCVP Launches ?Technology Challenge? to Accelerate Low Carbon Vehicle Innovation; Libralato Engines First Registrant
Old 12-21-2009, 10:37 AM   #25 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
The leanest has been 30:1
At 22:1 up the load increases a lot. My best FE has been at 22:1 so far.
I want to run it at 30:1 for NOx reasons.
The mix across all four cylinders has been good. I'm still messing with individual fuel controls and feel I haven't dialed it in yet.
Old 12-21-2009, 09:16 PM   #26 (permalink)
Too bad that's not a dual cam. I'd be interested to see the effects of a late intake valve closing on that setup.
The Following User Says Thank You to greasemonkee For This Useful Post:
pgfpro (12-21-2009)
Old 12-21-2009, 09:18 PM   #27 (permalink)
30:1 with shorter gearing or smaller tires will put you back in the zone where you're making optimal power to not overload the engine. There will be more wear on internal components due to engine speed, but meh.
The Following User Says Thank You to Christ For This Useful Post:
pgfpro (12-21-2009)
Old 12-21-2009, 09:18 PM   #28 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I would love a chance at testing this. There would be a ton more adjustment
Old 12-22-2009, 01:05 AM   #29 (permalink)
Smeghead
Thats pretty cool. Speeking of cool your exaust temps must be pretty low.
What ideas do you have to get timing back to where you are getting peak pressure with the crank 90 past tdc?
When I was thinking about using a carb to get lean for my rig with a vernier type prop knob attached to the distributor and adjust to best power once as lean as I could go.
Old 12-22-2009, 01:50 AM   #30 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Yes the exhaust temps are very low during lean burn
This is a issue I'm working on. At anything above 20:1 A/F my timing for max power at light load is in around 40* BTDC. I have a way to control the flame kernel in the prechamber to help this but I ran out of time this last year.
Lean burn is pain in so many ways.
I'm trying to get over a 30:1 A/F ratio to help with NOx but in doing so my BSFC numbers increase drastically. Not good.
If I use my new EGR systems to help NOx I lose power and need more air/fuel to over come it. Not good.
If I drop the A/F ratio down to 22:1 I'm sure I can get 80mpg(before the aero mods) at 55mph with more tweaking with the timing advance,flame kernel adjustment, and pulling more vacuum on the crankcase,but it won't pass emissions on gasoline with these settings and I would have to cheat the system by running two different tuning maps.
MetroMPG mailbag: how to keep SG live when engine off? MetroMPG Instrumentation 6 10-17-2011 03:44 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 02:32 AM
Video: Armory Lovins, Rocky Mountain Institute - promoting design of efficient cars Smoky Aerodynamics 6 05-10-2008 04:06 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
