Old 12-22-2009, 07:47 AM   #31 (permalink)
Originally Posted by bestclimb View Post
What ideas do you have to get timing back to where you are getting peak pressure with the crank 90 past tdc?
This would produce a lot of light under the hood
Old 12-22-2009, 12:10 PM   #32 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Whatcha mean?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 12-22-2009, 12:21 PM   #33 (permalink)
...beats walking...
..."glowing" hot metal parts in the exhaust system.
Old 12-22-2009, 12:27 PM   #34 (permalink)
Smeghead
If he is that lean and not making much horse power loping down the road at 55 it would lack the heat necessary to make metal glow.
Old 12-22-2009, 12:49 PM   #35 (permalink)
Less heat yes, but CFM is the problem (would require a lot of throttle with that kind of timing to produce 20 hp). The same reason 1600*F egt at part throttle does no harm, but WOT at those temps are on the threshold of melting engine parts, especially in a forced induction app.
Geometrically there is little mechanical pressure/energy extraction taking place at that crank angle. 10-20* ATDC is a common window for peak cyl pressure.
If the pressure curve didn't resemble a sine wave that number would probably be different.
Old 12-22-2009, 01:08 PM   #36 (permalink)
Smeghead
When I see operations with leaning WOT is very common. WOT rich to accelerate, then lean down to enough horse power to keep you moving at an acceptable speed. At the same time watch the EGTs plummet. At 20 hp he is down around 15% hp egt should be nowhere near the point of melting deposits on the exhaust valves or heating up the exhaust manifold. Unless it's is not running lean enough? Putting the timing into the point where the most mechanical energy is extracted seems like a good way to go.
Please note that I am not trying to argue a point here I am trying to reconcile my knowledge of leaning in aircraft with the possibility of doing so with an automotive system. With an engine with good mixture distribution the bottom threshold for lean is when cylinders start not firing due to a mixture too lean to support combustion and the thing starts missing. At that point the EGTs are up to several degrees lean of their hottest.
on an aircraft engine you are typically running at 50-60% of max rated in that configuration.
Old 12-22-2009, 02:25 PM   #37 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Whats with the "Other popular topics in this forum... " spam looking thing in this thread and others between post 31 and post 32??????????
Pressure Gradient Force
The Positive Side of the Number Line
Old 12-22-2009, 02:34 PM   #38 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
LOL, not spam, just the admins experimenting I'm sure
Old 12-22-2009, 02:36 PM   #39 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I Know,LOL I just had to raz them a little
Old 12-23-2009, 11:24 AM   #40 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
This is what I built my engine design around.
This is what a normal standard engine would look like. Since I'm running a lean burn engine now I need to start the ignition earlier so I will still have max pressure to take place around 10-20* ATDC.
MetroMPG mailbag: how to keep SG live when engine off? MetroMPG Instrumentation 6 10-17-2011 03:44 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 02:32 AM
Video: Armory Lovins, Rocky Mountain Institute - promoting design of efficient cars Smoky Aerodynamics 6 05-10-2008 04:06 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
