View Poll Results: Should I do one last engine flush?
Yes, do that before oil addative, cleaning out more crud from previous neglect is only good 2 66.67%
No, you already did two flushes, no need to do more, engine is the cleanest it can be by now 1 33.33%
Voters: 3. You may not vote on this poll
Old 10-23-2020, 05:45 PM   #21 (permalink)
SkauneJohan's Avatar
The cruiser - '93 Mercedes 200D
90 day: 38.11 mpg (US)
The rocket - '94 Mercedes E220
90 day: 32.29 mpg (US)
miss Habanero - '95 Audi A6 2.5 TDi Avant
90 day: 43.52 mpg (US)
Annie - '89 mazda 626
90 day: 29.51 mpg (US)
Originally Posted by hayden55 View Post
Dump and soak overnight then throw some rags over the spark plug holes and crank a couple times then throw it back together and go drive around to get to operating temp to burn the loosened carbon off.
You do know this is a diesel right?
1993 mercedes w124 200D automatic 75hp
1989 mazda 626 2.2 automatic 116hp
Old 10-26-2020, 02:24 PM   #22 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Ooops forcive habit lol
Well if you can get to the injectors and get them off maybe?
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 10-27-2020, 10:39 AM   #23 (permalink)
Ok then pour cleaner stuff into a fuel filter.
Old 10-28-2020, 12:53 AM   #24 (permalink)
Messing with the glowplugs would be easier, as it wouldn't involve dealing with fuel at high pressure which may be quite dangerous if done withouth a previous draining of the pressure.
