08-02-2012, 09:26 AM
Ethonal blended gas Vs. %100 gasoline
Has anybody noticed a difference in fueling up with E10 or E15 vs. fueling up with %100 gasoline when its available? Just looking for others input and ideas.
08-02-2012, 09:33 AM
Yes
http://ecomodder.com/forum/showthrea...l-18896-3.html
Stratus got 36.09 mpg E0($3.45) $0.09559/mile
35.58 mpg with E10 ($3.35 gallon) $0.0941/mile
So E10's cheaper per mile, in 1000 miles it will save me about $1.
The Following User Says Thank You to roosterk0031 For This Useful Post:
08-02-2012, 10:19 AM
In my vehicles the difference in price is not worth the small increase in mileage. Maybe if the price difference was less than 20 cents a gallon, but no more that that amount.
regards
Mech
08-02-2012, 11:06 AM
I personally haven't noticed a drop in mileage from E10 from any of my vehicles. I'm sure its there, but its just not noticable. I know others will chime in with claims that it kills their mileage though. In reality every engine will react differently to a different formulation of gasoline.
08-02-2012, 11:34 AM
Thanks for the info guys!
I've heard alot about ethanol E20 and up damaging fuels systems too. Alot of gas stations in Michigan are allowed up to 20% before even posting it! I've had alot of luck with mobil gas, my wife gets around 25-28 city in her taurus 12 valve but using the discounted kroger gas up to $1.00 off she drops down to 19-22 it depresses me.
08-02-2012, 12:24 PM
...beats walking...
Ethanol affects "older" carbureted-engines far more than "newer" injected-engines, because carburetors are air-mass-ratio devices that can't "adjust" for the presence of ethanol, whereas, computer-control injected engines can/do by adjusting injection volume and ignition timing.
08-02-2012, 12:50 PM
I've noticed as much as a 3 MPG difference, but it's usually around 2. As far as cost goes, it's a wash at the moment and ethanol free is hard to come by. The station I use is 20 miles from my house and I have less reasons now to go that direction, so E10 it is unless I'm in that area.
08-02-2012, 12:53 PM
Couldn't you re-jet to adjust the volume? We had more real gas here when my Camaro was still on the road, but it was a little rich anyway on the bottom end. Maybe it will be okay?
08-02-2012, 02:44 PM
#9 (permalink)
...beats walking...
...probably, but my understanding is that the actual percentage-of-ethanol in the gasoline 'blend' can/does vary with each different tanker truck delievery because the ethanol is "added" into the 'straight-stock' gasoline after its received from the delivery pipeline source, just prior to its delivery to the gas station (to reduce water absorption), so each state/locale has different proportions on an almost daily basis! Notice the labels typically read "...up to XX% alcohol..."
...so, carburetor adjustments made today probably wouldn't be as good or effective when you make your subsequent tank fill-up.
08-02-2012, 03:04 PM
#10 (permalink)
That discounted Kroger gas comes from the same facility that handles bp, sunoco, and speedway.
