Old 06-05-2008, 04:44 PM   #21 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
I think it kind of interesting that the smaller tire there was a pretty big jump until about 45 psi while the bigger tire was at a lower pressure of around 35. I would of thought that it would of been the opposite.
"Judge a person by their questions rather than their answers."
Old 06-05-2008, 08:10 PM   #22 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by dcb View Post
re: variance. Did you mark your starting position in two dimensions?
No, I didn't. It's possible (likely) I was off laterally a little from run to run.
On the starting hill, I moved into position each time by sighting down a wall beside me that was perpendicular to the roadway, and creeping the car until my line of sight was straight down the wall. Then I stopped completely and released the brakes when the coast was clear.
Is there any reason to think that the brakes might not release evenly?
I wondered that too. I suppose it's possible.
Old 01-20-2009, 09:23 PM   #23 (permalink)
To put this into perspective for a metrompg.com post I'm working on (not up yet), here's the Firefly coasting results shown to scale:
click to zoom...
Old 01-20-2009, 11:00 PM   #24 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Regarding Lazarus' post on the larger tire having less difference in distance per PSI level:
The larger tire has significantly stiffer sidewall area, which reduces rolling resistance. Obviously it's 40-60mm wider (manufacturer's measurements vary), but that may not win-over the loss of friction and warpage associated with tall/thin sidewalls.
Old 01-20-2009, 11:24 PM   #25 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
What I find so interesting is the level of variation between runs, even with such a simple test.
Maybe the lube cooled off. There is a huge difference in coasting speeds in my truck w/ a 50F difference, and given the operating range of greases/oils I imagine there could be a pretty big increase in drag relative to the change in Crr at those speeds as stuff cools.
Old 05-12-2009, 07:01 AM   #26 (permalink)
noxman's Avatar
MetroMPG:
What pressure are you using for every day ?
Thank you.
1.Fiat Punto 1.1 8v 40 Kw - 1996. 4l/100km with external board computer http://www.youtube.comwatch?v=P0Eq_m1VhBQ
2.Fiat Punto 1.2 8V 44kw - 2002, LPG injection system, trying to be eco... Video shows my lpg system and ride.
http://www.youtube.com/watch?v=FlQ-Xl6aIj0
Old 05-12-2009, 02:23 PM   #27 (permalink)
50 ish.
Old 05-12-2009, 03:17 PM   #28 (permalink)
distance
Darin,my thoughts are that if the car had been tested from some initial velocity,to a lower velocity,or stop,that you might have seen a greater spread in the data.Evidently,the starting force,which must be overcome just to get a car moving is remarkably high,compared to once its rolling.This is a reason for the traffic light synchronization,as "stops" eat a lot of energy.---------------- I think this effect is cutting into your numbers,although I realize the added complexity and variability of the coast-down.My suspicion is that your RR performance is actually much better than the numbers reflect.Your test does reflect a measurable effect so I say it's useful to all,kudos to you and !muchas gracias!,Phil.
Old 05-12-2009, 10:08 PM   #29 (permalink)
I agree, a "normal" coastdown from some moving speed would have made for a better test, Phil. No argument there.
Old 08-02-2010, 03:17 PM   #30 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
Thanks for posting and running the test. Has anyone had a blowout from running pressures exceeding the tirewall max?
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
