Old 01-24-2013, 09:06 AM   #11 (permalink)
90 day: 19.36 mpg (US)
Good start, Dave!
Old 01-25-2013, 11:34 PM   #12 (permalink)
Annette - '04 Ford F150 FX4
Penelope - '08 Mazda CX-7 Sport
90 day: 23.47 mpg (US)
Side-project: air intake
As a side project I researched here, and looked at my air intake.
At its narrowest point, my air intake is a circle 1 7/8th inch in diameter, which I think is quite small and limiting in an open throttle situation. Regardless of the Cold vs. Warm intake debate going on inside my head, I drew some conclusions, and one was that this restriction had to go.
If you look at the first three attachments,you'll see the intake restriction. I saw on here a "gotts mod" to widen that restriction out to the full diameter of the hole in the side wall. However, I decided to go a different route.
I took some A/C duct material, which is a 1.5" thick fiberglass insulation sheet coated on one side with reinforced aluminum. I removed the restriction, and made an air box like would be found on a cold air intake. I left my air filter arrangement intact.
I did this non-destructively, so when there is good weather, I can do an ABACADA test with and without the obstruction.
Here's my method, theory of what I expect to see:
METHOD:
I will note the temperature, wind and road conditions, and start with a fresh tank of gas with no additives, and a well warmed up truck.
A) I'll ultragauge my consumption at 55, 65 and 75 with the original intake. I'll note the intake temperature, fuel rate, speed, and engine load.
B) Then I will remove the restriction and repeat.
A) I'll replace the intake and repeat.
C) I'll put in the box, to in theory draw in cooler air, repeat
D) I'll remove the restriction and place some drier hose on the end, drawing air from the radiator, and repeat.
I will check that each A run is consistent, and create a graph of all the data collected during the runs and publish it here, with a photograph of each configuration.
I expect to see a baseline for A runs, a slight reduction of economy with the C run, and improvements with the B and D runs.
The EPA says that on the freeway, I should get 17mpg. Not knowing their method, I'll get those baseline consumption vs speed curves. From the baseline of 17 mpg, at 68mph that's 4 gallons/hr. That means 58.8 gallons of air would be consumed in an hour at a fuel:air ratio of 1:14.7, or a gallon a minute. That sounds like a lot less than I'd imagined, so I suspect my math is wrong? Anyone in the know want to weigh in?
I'm interested in suggestions for other things to check to improve my method, and also, any other possible configurations I could add to the test? Comments/ideas strongly welcomed!
The other attachments show how bad the underside of the truck is - it's like an aerodynamic grand canyon, and I have some firm ideas of what I'd like to do about it. More on that in a future post.
ID:	12337   Click image for larger version
ID:	12338   Click image for larger version
ID:	12339   Click image for larger version
Old 01-26-2013, 07:13 PM   #13 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
Fuel air ratio is figured by weight. That 4 gallons of gasoline weighs about 24 lbs, so 24 X 14.7 = 353 lbs of air. Next you need the density of air, which comes from a pschrometric chart (Google is your friend to find one). Air density depends on temperature, humidity, barometric pressure, and altitude. Psychrometric charts assume the altitude is at sea level, and standard barometric pressure.
Air density can range from over 15 cubic feet per lb (hot and humid) down to less than 12 cubic feet per lb (cold). Air at 70 deg F and 50% RH has density 13.5 cubic feet per lb.
Next, multiply 353 lbs X 13.5 cubic feet per lb = 4763 cubic feet per hour = 79 cubic feet per minute. And that's your air flow.
Old 01-26-2013, 07:50 PM   #14 (permalink)
Ah, so thinking volume was a mistake, weight is correct. Thanks for explaining it to me.
I didn't have good testing conditions today. I do know that up to now my base MPG is 17. With the fan delete and the restriction removed, but no other mods, I have been getting 19.9mpg in mixed driving with a few red lights, town, some 55 and a good 65 run.
I'm hoping with the aerocap and a few other changes, I'll be up around 24-25 mpg, which means the F150 4x4 would be beating out the CX-7 for economy
Of course, I'll be working on the CX-7 too, so... If I can get that over 30mpg I'll be happy.
Old 01-27-2013, 05:14 PM   #15 (permalink)
Under body panel.
I have decided the method and materials I'll use to build and attach my under body tray.
I will use tape and expanding foam to make a template/mould, then make a set of fiberglass panels that will be installed from the rear to the front, overlapping. This will make for the most lightweight and easy to install/remove system, at moderate cost/effort.
I know how to work around the exhaust, and am comfortable with that side.
I also plan to leave toom for suspension travel causing the driveshaft to move lower when the suspension unloads into a dip.
Where I am unsure is the differential. Will enclosing it or putting it out of airflow cause it to get significantly hotter? What is a normal temperature for an F150 differential after some freeway driving?
I will use my infrared thermometer to collect trip temperature data after longer drives for the next few weeks and report back, but any insight would be helpful.
Old 01-27-2013, 06:23 PM   #16 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Yer differential will git warmer in temp when it's enclosed with a belly pan. Temperature will depend on the loading (towing/bed load). Best thing to do is run a thermometer probe on the differential and measure yer temps and git a baseline before you install yer belly pans. After you install yer belly pans, you'll be able to tell how warm yer differential will git up to and if you'll be comfortable with those temps or not. Just don't go blind and not use some sort of continuous temp monitoring setup.
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 01-28-2013, 09:37 AM   #17 (permalink)
Something that came up recently with my pickup. At 7,900-lbs, and two destroyed tires, I had to order a rollback wrecker. We had to find attachment points to winch the thing up the bed. So, be sure to keep this in mind with any bellypan.
Old 01-28-2013, 02:33 PM   #18 (permalink)
*nods*
I can see how that would be a problem. Also, getting under there if it was dropped the height of the tires would be an issue too. I will look at the rear attachment points and make a plan.
Good call. Thank you.
That's a nice Airstream you have there. Single axle at that length, is it a 50's pre-torsion axle one?
Old 01-28-2013, 07:18 PM   #19 (permalink)
90 day: 51.82 mpg (US)
Late to the party, but subscribed and watching with interest.
And thumbs up for the "open source" and willingness to share approach.
Plans to A-B-A test the cap when it's finished?
Old 01-28-2013, 08:28 PM   #20 (permalink)
Bring on the turd polish!
mackerel's Avatar
Pablo - '86 Toyota Pickup 1 Ton, 22RE, W56 trans, 4.300 diff.
Pickups
90 day: 25.68 mpg (US)
Red Brighton - '98 Subaru Legacy Wagon Brighton
90 day: 32.3 mpg (US)
Rust Victim - '00 Toyota Tacoma SR5, 2WD, 5 speed manual, 2.4l, Extracab.
Last 3: 29.68 mpg (US)
I'm still designing a cap for Pablo's bed. It's a 7' x 5 1/2' flatbed with stake pockets. I'm also going to need full side skirts. It's just a little cold out there to get it done tonight.
I drew the horizontal line 4' straight level back from the front of the cap, then angled it down to end 8" above bed level 12" back from the back end of the bed. Then I did a spline curve from the front to the midpoint of each of the lines, and then to the back end of the sloped line. I think this will give me room for a decent side door. The sides will slope so that it's 45" wide (cab top width) in front and 48" wide in back. That will involve torturing the ply on the sides slightly, but it's within doable limits.
My plan is to cut two templates out of scrap and bend a properly trimmed 4x8 sheet over them, set the side pieces in place and mark them to that curve on their angles, and then put it together with some interior framing. I'm imagining a large hatch in the roof piece to make loading easy, but I haven't worked out those details. As I said, there'd also be a side door.
The Following User Says Thank You to mackerel For This Useful Post:
aerohead (07-10-2013)
aerocap, f150
