Old 11-07-2016, 01:42 PM   #111 (permalink)
100 mpg 1 tonne truck
teknomage2012's Avatar
Z - '77 Datsun 280Z 2+2 custom
90 day: 31.85 mpg (US)
Bumble Bee - '06 www.mpgtrikes.com nomaOmatic x1
90 day: 76.46 mpg (US)
VW Caddy Pickup Truck - '81 Volkswagen Rabbit Caddy Pickup Truck
90 day: 33.1 mpg (US)
KLR - '09 Kowasaki KLR 650 Dual Sport
90 day: 54.65 mpg (US)
The Juggernaught - '65 Gillig 35' motor coach
90 day: 6.55 mpg (US)
hummingbird - '81 Volkswagen rabbit vx
90 day: 165.09 mpg (US)
HD Ruby - '12 nissan leaf sl
90 day: 99.66 mpg (US)
Eco Ruby - '12 Nissan Leaf Sl
90 day: 169.6 mpg (US)
Billy - '01 Dodge 2500 2wd
90 day: 18.38 mpg (US)
Send a message via ICQ to teknomage2012 Send a message via Yahoo to teknomage2012
Since Reciprocating = Maintenance Your best choice in a prime mover APU engine on the used for cheap aftermarket is a : capstone c30 air bearing turbine engine with high efficiency waste heat recouperator.
Capstone Micro Turbine Natural Gas to Electric Generator Model 330-30 | eBay
Rated for 25,000 hours of nonstop continuous full power delivery of 30 kW or 40 HP, between inspections. The capstone could power your Nissan leaf at over 80 MPH continuously down the freeway for over 3,000,000 miles! And not one drop of messy lubricating oil or gross oil filters ever need be changed!
Though you will go through many tires, several CV axles, and a barrel of bug juice....
IMHO this type of prime mover is the only that should be allocated resources and materials to be produced globally.
Now with the transmission difficulties of efficiently coupling 100,000 RPM to the road solved by the advent of the electric power train, and both now available cheap on the aftermarket; it would be the choicest persuit of any serious ecomodder.
We need a topic in our forum full of case studies of ecomodder built turbine electric hybrids.
Wrightspeed Announces Super Clean Garbage Trucks | Wrightspeed Powertrains
If garbage trucks can see such vastly improved fuel economy, imaging what us ecomodder will do!
Even now Nissan leaf and even tesla power train parts are hitting the cheap used aftermarket on ebay for us to start building with.
2015 Nissan Leaf Complete Powertrain Motor, Transmission, Inverter and Charger | eBay
If interested I have a c30 turbine APU engine without grid tie circuitry and cabinet for such a build I could part with for $3500. Just PM me.
How to get a 100 mpg 1 tone crew cab truck for under $10,000; buy a nissan leaf!
The Following 3 Users Say Thank You to teknomage2012 For This Useful Post:
freebeard (11-07-2016), Isaac Zackary (11-07-2016), sendler (11-08-2016)
Old 11-07-2016, 01:48 PM   #112 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Ya. I've thought about doing an air cooled VW engine. But in order to get better emissions I was thinking either using such an engine with either a turbo charged or large displacement with a high compression ratio and a very low air to fuel ratio (30:1) running on propane.
Old 11-07-2016, 05:28 PM   #113 (permalink)
Full sized hybrid.
That would be awesome!
Old 11-07-2016, 11:06 PM   #114 (permalink)
Yes. Yes it would.
What are the dimensions of the APU?
Forget what I said about the Tesla roof tiles; they are less efficient. But they do have an interesting clip-together circuitry. The new 14.5 Kwh Powerwall instead?
The Dunn-Wright is a 2-cylinder 4-cycle engine and a 2-cylinder 2-cycle compressor. I was thinking of a utility power trailer, that could provide electricity, compressed air and propane, and would be useful parked at home.
Old 11-08-2016, 02:57 AM   #115 (permalink)
Full sized hybrid.
Now it wouldn't make sense to get to carried away with a pusher trailer. After all, it would only be for occasional use, and it would only have to put out a near average power.
A 20hp Honda or Kohler V-twin engine chained directly to the wheels would work. The problem I find with such a system are the emissions. The Leaf is considered a zero emissions car (although we know that isn't true.) So it would make sense to me to put on an engine that gets at least ok emissions. Maybe a propane engine with water injection and a catalytic converter would do the trick??
Old 11-08-2016, 06:58 AM   #116 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
They claim 90% efficiency. But the best dual cycle grid scale turbine plants are very happy to boast 65%. Still that would be far better than any hybrid ice drivetrain.
Old 11-08-2016, 09:35 AM   #117 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
It would be a major headache to implement - maybe do it up similar to how ZipCar does their subscription service? - but a range extending pusher trailer for things like Leafs that could be shared around among the local Leaf community would be smart. That would put the investment to work better.
I don't have an answer for the emissions statements except to recommend the best engine you could possibly install along with the simplest possible drivetrain to minimize losses - chain direct to the drive wheel, I guess. And shape the trailer for whatever aero advantage it could provide.
Old 11-08-2016, 09:42 AM   #118 (permalink)
sendler's Avatar
An electric vehicle doesn't need a pusher. Just and electrical cord.
Old 11-08-2016, 11:11 AM   #119 (permalink)
Full sized hybrid.
Yes. All electric would be ideal. But to get to Denver I'd have to cross the continental divide 3 times and climb mountains up to 11,500ft and down to 5,000ft. Some stretches there's no place to plug in until I'd be barely there on one bar, if I don't use AC or heat and drive like my grandpa. So about once a month I'll have to take the 1985 Golf with its black smoke cloud.
Now if I had an extension cord and a range extending battery/solar panel or the like, perhaps mounted on a trailer, that would be ideal. An aluminum air battery would be great! But if a battery costs the same as another car...
Old 11-08-2016, 12:23 PM   #120 (permalink)
sendler's Avatar
Uhhh? I meant from the generator/ trailer to the car. The trailer doesn't have to push an electric car. Just plug in. As long as we are off in dream land.
The Following User Says Thank You to sendler For This Useful Post:
Isaac Zackary (11-08-2016)
