Old 11-13-2011, 10:48 PM   #131 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
well for my next mod it will be a full belly pan. i finally found coroplast in my area for only $17 for a full sheet. now I just have to get my trailer tags done. Then i can get my truck empty and go pick it up. then after the belly pan it off to the inside for some instruments. vacuum, mpguino, volt meter. add the kill switch and alternator kill switch then i'm done. I am still kicking the idea around about the no power stearing... I dont know yet.
Old 11-14-2011, 12:46 PM   #132 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Just ordered one of these to tweek my alignment: Caster/Camber Gauges - RPW Caster-Camber Gauge
Old 11-19-2011, 08:20 PM   #133 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
And they pay for themselves on the first use.
Because I didn't have enough going on in my life, I just fell into a 1.6 litre diesel engine with a lower geared transmission than the one in my Jetta. It's out of an '85 Golf. Got the whole car( not quite worth saving) for $350. TMFP, and here comes winter. Sometimes I even make ME wonder.
My son has renamed my car as the "Franken-Jetta". Guess I should change the garage.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 11-19-2011, 09:11 PM   #134 (permalink)
Team ZX2
Once you go Diesel, you'll never go back!
Old 11-19-2011, 09:38 PM   #135 (permalink)
Diesel
Been waiting for over 10 years to get a diesel for a veggie conversion. Only thing is, I won't be able to compete with you guys. Guess I'll just have to take over the diesel column.
Boat tail project
Old 11-21-2011, 12:34 PM   #136 (permalink)
Team ZX2
Well, the alignment was pretty far out. Too much toe front and rear. I also found a sticking brake. It coasts so much better now. It probably won't show for a couple of weeks because it won't stop raining and people won't stop crashing and causing delays on my commute! I can't believe my mpg was so good this summer with these issues....can't wait to see what it's like when it gets warm
I've been having some other issues with the car, but with 299,197 miles on it, I can't really complain. Got a worn out acc. pulley and it wont' get over 180 degrees...so I still got a little mpg to be gained.
As I was laying under the car, adjusting the tie rods, I began to dream and plan a belly pan. I got some work to do before that though....
I've also got a Diesel project I'm itching to start
Old 11-21-2011, 08:00 PM   #137 (permalink)
Diesel
Sweet finds. I'm going to look into those alignment rigs. We do alignments at the shop, but converting the sensors from 18 wheeler size to car size sucks.
Diesel Escort for the win.
Boat tail project
Old 11-21-2011, 08:55 PM   #138 (permalink)
CRX - '90 Honda CRX HF
Fantastic job!!
Old 11-21-2011, 09:03 PM   #139 (permalink)
Team ZX2
No, not the escort
It already has a diesel, but is really in need of some mods. I'll start a thread about it when the time comes.
More people need to do thier own alignments. It really isn't as hard as it may seem. Just some math and careful prep work needed.
Old 11-23-2011, 08:07 PM   #140 (permalink)
Diesel
Got my Caster/Camber Gauges - RPW Caster-Camber Gauge on order. Should save a bundle on alignments. Thanks for the tip Ty.
Boat tail project
