Old 06-06-2011, 01:20 PM   #21 (permalink)
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
it is not necessarily the compressor that is inaccurate it is the hose that causes the issue. having a regulator at the end of the air hose will be more accurate. I use one very similar to this. Tire Inflator w/ Dial Gauge
I also have this one same brand but my button is in a different spot to relieve air.
Moroso 89560 - Moroso Tire Pressure Gauges - Overview - SummitRacing.com
After each use I drain my air tank of water to make sure not putting it into the tire. If you don't have a large compressor and rely on a shop to getting your air I would suggest a small portable compressor like mentioned already.
to see if it is accurate I use my wifes Cadillac with the tpms the on board computer tells you tire pressure. Comparing that to the moroso and the in line gauge it is within 1 lbs of the in car monitor when cold.
Look at summit racing they have tons of gauges 197 is what I got in my search
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
Old 06-13-2011, 04:28 PM   #22 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
I'm now the proud owner of 3...yes...three...el cheapo dial type tire pressure gauges.
Amazon.com: TEKTON by MIT 5938 Dial Tire Gauge - 100 PSI: Home Improvement
Had to glue the rubber gasket into it...bezel is glass...domed and too likely to get cracked...only paid $7 though. Reads at 42 PSI.
Amazon.com: 4X4 Accu-gage: Automotive
Larger and bulky...but easy to use. Has a rubber shield on the dial. Reads at 41 PSI. I paid ~$7.
Buy Victor Tire Gauge with Bleeder - Dial - Mini 22-5-60023-8 at Advance Auto Parts
Probably the best of the 3...has a case. Reads at 42 PSI. On sale for $5.
ALL of these have a release button so you can remove them from the tire and see the pressure.
Best bet? Buy 2 of the last one and make sure they agree and agree with a Master gauge. When one shows an off reading...buy another?
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
The Following User Says Thank You to suspectnumber961 For This Useful Post:
justjohn (06-13-2011)
Old 06-13-2011, 07:50 PM   #23 (permalink)
Black Beauty - '13 Hyundai Elantra
Looks like a pretty good solution. Might do that plus a bike pump.
Old 06-13-2011, 10:15 PM   #24 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
get a digital gauge. i've never had one in good working order be off by more than +/- 1psi. that being said, cheap, $10 or less / walmart gauges... dont stay in good working order long term, i've had one give wacky readings after being dropped about 4', and i've smoked one after getting it in water less than 1/4" deep
i've been using a matco DT100 gauge for about 2yrs now, been dropped, soaked and im sure ive checked over 1000 tires since ive had it and no trouble. only $28 on thier site Vehicle Service, Wheel & Brake | Matco Tools Online Tool Catalog
