Old 04-29-2016, 02:35 PM   #21 (permalink)
He-man's Avatar
Rocket - '99 Chevrolet Corvette
90 day: 31.51 mpg (US)
Pooter - '01 Honda Insight
90 day: 66.9 mpg (US)
Originally Posted by Natalya View Post
Do you have something to get the engine temperature? I've been hesitant to do any kind of grill blocking until I get my engine thermometer set up properly.
I don't have any way to tell, the temps are in the same place as they were before on the OEM gauge so i don't think anything is super out of whack. I have noticed after a bit of driving an improvement in distance i can coast and a good 1-2 mpg increase at 55mph
Old 04-29-2016, 02:51 PM   #22 (permalink)
90 day: 39.99 mpg (US)
The OEM gauge allows for pretty huge swings in temperature before it registers. However, I expect that unless you live in a very hot climate (which you don't), you will have no problems.
Might I recommend a cheap eBay bluetooth OBD II reader? You can pair it with an android app such as Torque to get readings on all sorts of interesting data.
Old 04-29-2016, 06:19 PM   #23 (permalink)
Happiness is a warm...
transmission.
Old 04-29-2016, 06:21 PM   #24 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Originally Posted by He-man View Post
What should the temps be around?
Coolant temp or engine bay temp?
Fer yer engine bay temp, you'll have to determine yer baseline before all yer mods. Then after the grill blocks, belly pans, etc are added, you'll be able to see how much it has affected yer engine bay temps.
Coolant temps will vary depending on the load or engine type. Fer my T-100, I'm seeing between 195°F to 204° without any grill blocks.
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 04-29-2016, 06:33 PM   #25 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
All three of my family members with Insights run a full lower grill block, and it doesn't get much hotter than central Florida. None of us have ever had an overheating issue.
It would probably be a good idea to run torque, but I haven't yet
Old 04-29-2016, 08:51 PM   #26 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
How does this full lower grill block affect A/C?
I just got my 2000 insight a few weeks ago and I am getting the mod itch.
I removed the front plate holder and lowered the plate to cover the middle of the lower grill.
2000 Insight MT 106K Citrus A/C
