Old 08-18-2010, 12:36 PM   #1 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Fresh air to ... the battery ?
Looking under the hood of my Volvo V50, I noticed there's a small air duct in the hood's sound-proofing that force-feeds fresh air from behind the grill to the largely enclosed battery.
For me, it's the first time I've seen anything like this on any car.
Why would Volvo do that ?
If I block the grill, that'll also bock the air to the battery.
What effects are to be expected ?
Old 08-18-2010, 12:41 PM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
It is there to keep the battery cooled. If it is mostly enclosed than most of the heat from charging or discharging is contained (not good) and can cause the battery to over heat. I would still let some air flow into that area (it will also help keep other under the hood electronics cool).
Old 08-18-2010, 01:04 PM   #3 (permalink)
euromodder's Avatar
If I remove the enclosure along with the airduct, the battery will be in the hot engine compartment - like most other car batteries.
It goes only to the battery as far as I can see.
Where it goes after that, I still have to find out, but by the looks of it, it's not going to other electronics. Probably just spills out at the rear / bottom of the battery.
Old 08-18-2010, 01:24 PM   #4 (permalink)
Wiki Mod
yes it likely just spills out into the engine compartment, but it is good to have some cooling in there. Under hood temps are a key factor in how long electric components last.
As for the battery enclosure, the designers must have decided that it needed shielding from the under hood temps, that's why they put it in an enclosure. Heat kills batteries (speeds up the chemical break down process) this is not a big deal with lead acid
batteries but it still is a factor.
Can you post some pictures of the current set up and of you planed mods (tape some cardboard up)?
The Following User Says Thank You to Weather Spotter For This Useful Post:
Cobb (02-06-2014)
Old 08-18-2010, 06:17 PM   #5 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
Move the battery to the back seat like I did. More room to work on engine. More weight out of the front allowing 155/80/r13 wheels. Also cooler battery.
The Following User Says Thank You to busypaws For This Useful Post:
Cobb (02-06-2014)
Old 08-19-2010, 12:12 PM   #6 (permalink)
euromodder's Avatar
That's not really an option ...
But the spare wheel well is empty now.
Mmmmmmm
Old 08-19-2010, 05:14 PM   #7 (permalink)
It's not for heat/cooling. Batteries emit gasses thus need to be vented.
Old 08-19-2010, 06:11 PM   #8 (permalink)
Cool battery makes better FE and longer battery life.
When battery get hot the voltage of the battery goes down and battery gets overcharged. (I might say that overcharging is just boiling water) Cool battery has higher voltage and alternator won't overcharge it.
I haven't been any kind of Volvo fan but past year have been different. Volvo has done many basic and reasonable things for better FE and reliability and this is one more thing to list.
Old 08-20-2010, 10:00 AM   #9 (permalink)
...beats walking...
...yep, HYDROGEN (ala' "Hindenberg") gas...which might be an idea to the HHO generation advocates.
Old 08-20-2010, 10:50 AM   #10 (permalink)
euromodder's Avatar
The battery has been in there for almost 5 years.
I've only used the preheating maybe 1 or 2 times.
In winter it starts easily without using preheat, even though the car is not kept in a garage.
I could monitor the voltage using the Scangauge and see if there's any difference.
Fortunately - or unfortunately depending on your PoV - a car battery won't produce nearly enough hydrogen to have an effect on FE.
But in an open engine compartment, battery ventilation surely would be better than in an enclosure ?
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
DIY Solutions to Honda Hybrid Battery Problems (Insight, Civic, IMA) RobertSmalls Hybrids 265 06-18-2020 02:15 PM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 6 10-07-2013 04:13 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
