Old 11-19-2011, 06:48 PM   #31 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Here is my 'dead horse' that I keep bringing up from time to time.
This is proof that you can have a blunt 'barn door' front end and still have good aero.
This old '80 Camaro got down to a wind tunnel tested .201 Cd - or just over what the EV-1 achieved.
Chevy Camaro Aerodynamics Side View Photo 7
Also look at the attached flow with the 'barn door' flat front end on this '32 Coupe :
Notice the flow along the roofline as the smoke stream hits the vertical windshield.
Old 11-19-2011, 07:16 PM   #32 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Here is another '32 coupe - this one quite draggy by the looks of the smokestream.
Still, this video gives a good idea of how that a simple rounded edge can keep attached flow - for example along the roofline.
The Following 2 Users Say Thank You to Cd For This Useful Post:
aerohead (11-22-2011), California98Civic (11-19-2011)
Old 11-19-2011, 07:57 PM   #33 (permalink)
.201 even with that massive scoop??
Old 11-19-2011, 08:37 PM   #34 (permalink)
Originally Posted by Cd View Post
It would certainly be interesting to see a tuft test along the sides of those fenders Frank.
Its hard to tell without tufting it though.
( I hope you do get around to fixing that front end ! Good luck passing inspection without the turn signal lights )
It would be fun to tuft test vs one of my "complete" cars.
There are no inspections. There are turn signal lights.
Old 11-20-2011, 01:11 AM   #35 (permalink)
Cd
Ultimate Fail
Cd's Avatar
" We did lots of hoodscoop testing with Harwood's scoop part numbers (left to right) 3161, 3164, and 3182 borrowed from Barnett Performance. We also tried our old 6-inch cowl hood and a bone-stock flat hood we borrowed from Camaro Specialty and taped all the scoops in place on that hood. All the scoops were swoopiest when extended back to the windshield. Believe it or not, the cowl and the PN 3182 aero scoop had the very same Cd as the flat hood, and the other two scoops were just 10 counts worse. Better yet, the ram-air of the aero scoop was estimated to give us 24 hp at 250 mph. "
Read more: Chevy Camaro Aerodynamics Hoodscoop Photo 5
Old 11-20-2011, 09:35 AM   #36 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Frank, your Tempo pic reminds me of the truck grille I have not finished yet.
I get to make a scratch bumper for the truck, and I've been watching this thread. Thanks for all the good info. It looks like I need to build something resembling Jay Leno's chin, yet tasteful. Seems like a tall order to me
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 11-21-2011, 08:25 AM   #37 (permalink)
Quasi-Modder
While this is for the nose of a streamliner; it is still quite interesting.
http://www.aussieinvader.com/wp-cont..._design_dm.pdf
Old 11-21-2011, 09:40 AM   #38 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Phil has said this before and I'll repeat it for the sake of discussion. Attached flow is not the goal! The pressure at the front of a car is great enough to attach flow almost no matter the shape. In fact, if you show me a car without attached flow on the front panel I'll send you a nice drawing of your car.
Anyway. Reducing drag is the goal. Air will most likely prefer a nice, rounded front to a block front. And keep in mind that when you compare it to the EV1, you compare it to a stock car without the giant air dam or gap taping.
That's not to say a car with a flat front can't yield good numbers- the Camaro disproves that- but a smooth transition is preferable.
Carry on!
The Following User Says Thank You to Sven7 For This Useful Post:
Cd (12-11-2011)
Old 11-21-2011, 01:01 PM   #39 (permalink)
People continue to fixate on the front when the top of the windshield on back is where it's at.
The Following 3 Users Say Thank You to Frank Lee For This Useful Post:
Cd (12-11-2011), PaleMelanesian (11-22-2011), slowmover (12-28-2011)
Old 11-21-2011, 01:51 PM   #40 (permalink)
Very interesting.
Looks like you have a choice of safe and slow, or fast and air-born.
