Old 11-27-2014, 12:53 PM   #1 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
fuel sensor ~ obd2
How difficult would it be to connect the fuel sensor to obd2?
I'm interested to get more accurate fuel tank readings with the ultragauge.
As the fuel tank empties, a float drops and slides a moving contact along a resistor, called a potentiometer, increasing its resistance. The dashboard indicator displays the amount of electrical current flowing through the sending unit on a gauge. The potentiometer should read 2-5 ohms when empty and 105-108 when full.
Old 11-27-2014, 07:53 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Interesting question. Usually it's the guys with pre-OBD-II vehicles that are looking for more accurate ways to measure fuel used at the tank.
I don't know anything about fiddling with OBD-II. I'd be surprised if you could feed a new sensor into the system and then have the gauge read it though.
But I think you'd be able to buy or make a higher resolution digital gauge easily enough. You'd just have to calibrate it against an actual fill (done in measured increments) for accuracy.
j12piprius (11-27-2014)
Old 11-27-2014, 08:03 PM   #3 (permalink)
Liberty Lover
j12piprius's Avatar
That would be good, but shouldn't a new gauge adjust from the sensor in the tank?
Old 11-27-2014, 08:16 PM   #4 (permalink)
I assume you'd be going for a display with high resolution (eg. a % readout or 20 "bars" vs analog).
By "calibrate" I mean you could measure exactly how much fuel each bar represents. I don't think the float/resistor gives you a linear progression from full to empty.
Old 11-27-2014, 08:17 PM   #5 (permalink)
PS: what's your reason for wanting more resolution from your gauge?
Old 11-27-2014, 08:24 PM   #6 (permalink)
Liberty Lover
j12piprius's Avatar
Yes, high resolution.
My reason is for greater accuracy, verification of how many gallons to fill up, and a double check of fill ups from different stations.
Old 11-27-2014, 09:07 PM   #7 (permalink)
My understanding is that people with lean burn install an MPGuino.
Old 11-28-2014, 01:47 AM   #8 (permalink)
Wanting more for less
D.O.G.'s Avatar
Metric - '94 Honda Magna 250
Motorcycle
90 day: 69.83 mpg (US)
RedCelica - '94 Toyota Celica ZR
90 day: 35.97 mpg (US)
i30 - '12 Hyundai i30 Elite
90 day: 39.84 mpg (US)
i30-22 - '12 Hyundai i30 Elite
90 day: 39.22 mpg (US)
Most float type fuel tank level sensors aren't designed to be super accurate, so it throws out whatever display you use.
In a typical rectangular tank, climbing/descending a hill, cornering, road camber, how warm/cold the fuel in the tank is and probably lots of other outside influences will effect the displayed fuel level.
Some type of damping device is usually used to smooth out the reading, but they aren't perfect and will give false readings at times.
An MPGuino is pretty accurate, but even that ignores variations in fuel pressure and temperature, dirty or worn injectors, fuel leaks, etc.
This is why most guys recommend only filling from one particular pump at one particular petrol station at a regular time of day. Even then, there are just too many variables to rely on one tank's result, you have to average results over time.
The Following User Says Thank You to D.O.G. For This Useful Post:
j12piprius (11-28-2014)
Old 11-28-2014, 01:56 AM   #9 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
I think the fuel level sensor will already be reading its maximum value after filling at a pump that turns off a bit early, so the exact sensor reading won't help to determine how complete of a fill you are truly getting
Old 11-28-2014, 06:02 AM   #10 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I too would love an accurate fuel gauge.
At it's simplest, you can simply connect a voltmeter to the factory gauge, X volts means full, Y volts means empty. You could use an Arduino to translate this to actual litres/gallons.
However, as stated already, this would be of limited value as there's still fuel in the tank when the sender reads zero and you can always fill past full.
I've often thought about adding a camera inside the tank for visual confirmation, you could even add a tide stick inside with markings. Only way I can think of to have complete accuracy.
I once nearly ran out of fuel because I put too much faith in my MPGuino, luckily I was at the top of a hill when it began to sputter, and there was a petrol station at the bottom.
