08-17-2014, 01:42 PM
#321 (permalink)
Master Ecomadman
Wow, thats some boat anchor, I mean boat tail! How far does she coast now with no tail? Rear skirts would go nicely with tail II, hopefully the roughness friction factor will be improved.
- Tony
08-17-2014, 08:33 PM
#322 (permalink)
Wiki Mod
The costing is nodicably less. P and G at 55-40 was my past optimal now its 55-35 to get the best results.
08-18-2014, 12:08 PM
#323 (permalink)
halos.com
Question sir. When you installed the nosepiece, what kind of fuel economy difference did that make?
[edit] my condolences on the boat tail...
08-18-2014, 03:30 PM
#324 (permalink)
Wiki Mod
I added the nose and the rear belly pan on the same tank. My best estaminet is that the nose is good for about 2 mpg.
The Following 2 Users Say Thank You to Weather Spotter For This Useful Post:
08-28-2014, 12:24 PM
#325 (permalink)
halos.com
If you were getting 43mpg without the boat tail, then 2 mpg is about 4.5%. Better than I expected. Got plans to put a Kammback and a beak on my truck. Can hardly wait to hear the wife scream about that...
08-28-2014, 03:22 PM
#326 (permalink)
Don't forget the shark mouth.
08-29-2014, 08:22 PM
#327 (permalink)
Wiki Mod
I am thinking I might paint the teeth back on.... or do something new.....
I am even thinking of making the tail again...... not sure i can do that 1000 miles from home but I want a fun project..... my commute right now is only 10 miles so the pay back is never I should get a longer commute so I can justify modding.......
08-30-2014, 12:35 PM
#328 (permalink)
10-miles
That's an enviable situation to be in!
A modest-range EV would be more than adequate.Although your winters would really put it to its limits.
Thanks for the tail,nose, and shark teeth.
08-31-2014, 02:48 AM
#329 (permalink)
Then you can mod for engine warm-up time and reduce weight.
I started sawing off extra bolt length on my cars, it's free ! (But not measurable )
08-31-2014, 03:44 AM
#330 (permalink)
I know a guy who used to race motorcycles. He claims he drilled holes lengthways through the middle of bolts to save weight.
That sounds tedious.
