12-07-2009, 08:34 PM
#11 (permalink)
This is an even bigger waste of time than arguing about hho.
12-07-2009, 08:39 PM
#12 (permalink)
Wiki Mod
I will hang a large amen on that!
12-07-2009, 08:55 PM
#13 (permalink)
wow. that guy thinks alot.
Every car has a problem, you have to learn it.
could be porting/aligning heads ports for better,
the cfm and original design is always correct however, it is a set math revolving around common stoich. we can make it whistle a bit harder, and can even go too large to make it a slob.
don't bother overthinking it.
some carbs have no air bypass, and that is about the biggest hack needed modern day that I know of.
add supercharge if ya want. do whatever.
don't overthink it.
12-07-2009, 08:57 PM
#14 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Wait... how exactly does a throttle body modification compare to a combustion chamber modification? The same theories don't even apply...
Where'd you come up with that?
12-07-2009, 09:42 PM
#15 (permalink)
In Lean Burn Mode
Gadgetman
Oh boy Oh boy Oh boy...
Where to begin?
Pressure Gradient Force
The Positive Side of the Number Line
12-07-2009, 10:01 PM
#16 (permalink)
...beats walking...
Originally Posted by Weather Spotter
I smell snake oil....
...smells more like bovine meadow muffins to me!
12-08-2009, 02:33 PM
#17 (permalink)
You're right, they don't compare at all.
Sorry, my bad.
12-08-2009, 02:41 PM
#18 (permalink)
J. Shelby Christian-Goodyear, AZ-1999 GMC 1500-I can tell you that I'm only using about half the gas I used to-and the old girl's really got some energy now! It's hard to believe that such a simple thing can make such a BIG difference! Thank you, Gadgetman!
Anyone see something wrong? Frank'll see it right away... betcha a buck.
12-08-2009, 02:45 PM
#19 (permalink)
In Lean Burn Mode
A funny looking GMC???
12-08-2009, 02:47 PM
#20 (permalink)
Like I said, Frank'll know what's wrong exactly. You're right, though, that's not a GMC.
