Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 09-13-2012, 02:31 AM   #51 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by ConnClark View Post
A simple semi spherical bump is all that is needed to mix the slower boundary layer with the faster moving air above it.
The following report describes boundary layer control using all sorts of techniques. Included are VGs, Arches, Cylindrical posts, and many more.
But whatever sticks out into the airflow, is not very streamlined as a rule.
These gaspods are streamlined shapes, so while they will still push a bit of air up and aside, it won't be much, and it'll be done fairly gently, allowing the air to return to where it was before ... so where would their claimed effect come from ?
Old 09-13-2012, 11:54 AM   #52 (permalink)
...beats walking...
they "work" on exactly the same principle as VENDOR DECALS do on race cars--they make the cars "go" faster just by being there on the sides of the cars (wink,wink)!
The Following User Says Thank You to gone-ot For This Useful Post:
mcrews (04-10-2013)
Old 09-13-2012, 12:13 PM   #53 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
So my above-average milage is because of the vendor decal?
The Following User Says Thank You to Piwoslaw For This Useful Post:
UltArc (11-07-2012)
Old 09-13-2012, 02:34 PM   #54 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
The air that gets pushed up gets accelerated by the faster air. When it returns it accelerates the slower air. It may be less effective at re-energizing the boundary layer than other shapes but it does have less drag. Its a trade off. You can however use more of them to get the same effect.
Old 09-13-2012, 05:11 PM   #55 (permalink)
jalmir's Avatar
Avante - '02 Hyundai Elantra GT
90 day: 32.07 mpg (US)
bingo!
that ecomodder sticker must give you a good 5-6 better MPG!!!
stick a hundred of them on the car and it might just start pumping fuel back in your fuel tank!!!
The Following User Says Thank You to jalmir For This Useful Post:
mcrews (04-10-2013)
Old 01-28-2013, 02:08 PM   #56 (permalink)
Boltar - '19 Chevy Bolt LT
Suzie should just give use a few free samples to those interested, my humps my humps my lovely gas humps.
Old 01-31-2013, 08:28 PM   #57 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
I think these pod bumps could possibly work, but I don't see how one could actually get bonafide gains without precise placement on the vehicle. The information I've read about vortex generators and microvanes talks about how they have to be properly placed/positioned, or they'll harm airflow instead of improving it. This is the reason I've not tried any VGs or such stuff; I don't want to do hundreds of miles of tuft testing to see if I got it right or not, when there are several proven items I can install and benefit from...
Old 02-01-2013, 07:42 AM   #58 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
I'm not an aeronautical engineer but I know that if you are going to put VGs on a vehicle they need to not only be placed correctly but scaled to the application. If they are too small they might not affect the air enough and too big they would create more drag than without. That said they probably need to have the shape tweaked depending on where they will be placed and how large they are.
If the company was out to sell a product that reduces your aerodynamic drag there would be testing with many different vehicles. There would be instructions on where to place them and there would be different types of gas pods that are used for different vehicles and the unique shapes found on those vehicles.
Being $30 for a set of 3 my non technical opinion is there is insufficient proof to but 2 or 3 sets to attempt to reduce drag. For $60-$90 one can buy a lot of material for mods or instrumentation that are proven over and over to work.
Project Avalon: E bike build
Old 04-05-2013, 02:55 PM   #59 (permalink)
Knightrun - '08 Ford Mustang GT
90 day: 31.83 mpg (US)
Wouldn't a simple string test show if these did any good? But then, who's going to dump $60+ just to find out? These are the most expensive VGs (oops, non-VGs...?) I've seen on the market. You can make a ton of aircraft-style ones out of a $5 aluminum bar.
~SM
Old 04-10-2013, 01:44 PM   #60 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
No, a string test would only tell you what's going on with the layer of air right next to he car, which can be a helpful tool in some cases, but is only a very small piece of the puzzle.
The best test for these would be a fairly long steep hill where a car can coast at 50-60 mph then time how long it take to go a set distance, while keeping track of your speed, both with and without the aero enhancement. If there is a significant difference, it would show up on this test.
I would be shocked to the core if you could see a 3% variation testing Gaspods by Aerohance using this test.
aerohance, airfoils, gaspods, getpodded
