Old 06-22-2008, 12:47 AM   #1 (permalink)
Good Coroplast to Coroplast Adhesive?
I want to patch up some "oops" and bond some lap joints together. What's a good glue to hold this stuff to itself?
Old 06-22-2008, 09:24 AM   #2 (permalink)
I'd give super glue a try.
Old 06-22-2008, 09:25 AM   #3 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
I was wondering that very same question.
I was going to try using 3M spray trim adhesive (I have 2 partial cans on a shelf) That stuff seems to be able to hold just about anything to itself.
My other thought was to carry some coroplast to the craft store or home depot and ask them for advice.
And now a 3rd thought, asking the people who sold me the coroplast in the first place. They ought to know.
Shultz
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 06-22-2008, 10:07 AM   #4 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Honda Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 Infiniti j30
90 day: 22.74 mpg (US)
I'd try liquid nails or possibly gorilla glue.
Old 06-22-2008, 10:34 AM   #5 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I've used contact / rubber cement with coroplast (once). Worked well for me.
Cd (11-07-2015)
Old 06-22-2008, 01:59 PM   #6 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
Coroplast is made of polyethylene, so you need to use one of the few adhesives that will work with polyethylene, which is a low surface energy material that most glues will only attach weakly too. If you are careful, (since coroplast is hollow) you can also heat weld pieces of it together. McMaster-Carr sells an epoxy adhesive that works with polyethylene.
aerocivic.com
The Following 3 Users Say Thank You to basjoos For This Useful Post:
Cd (11-07-2015), theoteacher (09-26-2010), Xist (11-05-2015)
Old 06-22-2008, 02:13 PM   #7 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Walmart sells a 2 part glue (primer + glue) that says it works even with polyethylene. I know it is rare to find one that does work. Honestly Id try contact cement first, it seems like it would work a lot better for large surface area lap joints.
Winter daily driver, parked most days right now
Summer daily driver
Old 06-22-2008, 04:24 PM   #8 (permalink)
Thanks for the info. on just what coroplast really is, basjos. I found some information about bonding polyethylene by googling and found this writeup about a specialty 3M product, DP 8005:
http://www.stealth316.com/2-dp8005.htm
He talks about the special applicator -- I'd give just squirting it out on a piece of cardboard and stirring it up a try. It looks like it's available at "drillspot.com" here:
http://www.drillspot.com/products/32...astic_Adhesive
With ground shipping a single tube is about $25.00. I may want to live with my ugly lap joint for a while, or even try some really short sheet metal screws run in from the piece behind the visible surface to see it that's good enough for a while.
Edit to add: Sheesh, thanks again, basjos, for the McMaster-Carr reference. I'll see if the outlet near me stocks the stuff.
The Following User Says Thank You to garys_1k For This Useful Post:
Cd (11-07-2015)
Old 06-22-2008, 08:48 PM   #9 (permalink)
Meph's Avatar
240Z - '73 Datsun 240Z 240Z
90 day: 34.41 mpg (US)
construction adhesive works well for most anything
Old 06-23-2008, 12:42 AM   #10 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
you should try fiberglass resin on a sample piece.. bet it would work, there are different types of resins that are compatible with different types of materials..
Really i love fiberglass resin there are so many uses for the stuff.
Where did you buy Coroplast? tjts1 EcoModding Central 28 11-18-2009 01:12 AM
Coroplast undertray question (covering the control arms) Otto Aerodynamics 8 03-30-2009 12:27 PM
Fastening coroplast to the underbody Daox Aerodynamics 2 05-23-2008 02:57 AM
Coroplast question Otto Aerodynamics 14 03-27-2008 11:45 PM
