Old 01-05-2018, 10:50 PM   #11 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Reduce collection (all licensed/ running) from seven to four.
Save pennies for Eco-Supercar.
Old 01-05-2018, 11:09 PM   #12 (permalink)
I have finally learned my New Year's resolutions are worth the paper they're written on.
And they aren't written down.
So... none.
Old 01-06-2018, 12:22 AM   #13 (permalink)
90 day: 29.78 mpg (US)
What are your parents driving now?
Mom drives a 1998 Camry. Dad drives whatever vehicles I keep at the house, which is currently the Dodge/Cummins and Acura TSX. 99.9% of their trips are local, and electricity is cheap. Dad doesn't work on cars much anymore, so broken timing belts set them back quite a bit.
My wife is walking to work these days, and I work from home. Just got an email to turn in the company vehicle by April, so that will eliminate the Mazda CX-5.
I'm keeping the Acura because it's such a phenomenal car, and I plan to teach my kids how to drive a manual in the age of autonomous vehicles. The Prius is for camping/road trips.
As much as I enjoy learning how to work on ICE vehicles, I won't have as much time to spend on them when I have kids, and the knowledge will increasingly become irrelevant. I'll probably never purchase another ICE only vehicle.
Old 01-06-2018, 12:57 AM   #14 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
2002-2006 MINI 15" 7-hole imolas
Make/buy replacement 40ahr Lithium deep cycle battery
Final oil leak fixes
Pass SMOG test
1996-2000 HX trans swap (maybe)
Flat spoiler project
Driver door fix
Coling rad on/off
LeMons Rally 2018 (August)...
...and probably much more...
Old 01-06-2018, 11:54 AM   #15 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Get the CRXFi going!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 01-06-2018, 01:52 PM   #16 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Put a 8 point cage in my car for racing safety purposes and lighten a bit.
Removing my front mount inter-cooler and running a short charge pipe to the T/B with my IAT sensor, nitrous and alcohol injection nozzles in the pipe. So this pipe will be a hot or cold pipe depending on if the nitrous and alcohol is enabled.
Pressure Gradient Force
The Positive Side of the Number Line
Old 01-06-2018, 05:15 PM   #17 (permalink)
I seem to be hypermiling my Accord better than my Civic, but the smaller car has much worse compression, so I do not know for how long I will have two [running] cars. I tried to fix up a few issues with the Accord. Unfortunately, the car looks worse now than before the tire blew. I can sand and repaint the bumper, but the passenger door looks wavy.
My black ABS grill block matched my faded, scratched, and abused black paint, but I do not think ABS comes in champagne, and I do not want to make the pretty car look unattractive.
You guys remember I taped plastic to the front, right?
I have some ideas of how I want to improve on that. I admire how Metro installed a coroplast air dam without drilling holes, but I do not think coroplast comes in champagne, either.
Oh dear. My memory worked. Why did it have to do that?!
So... coroplast is considered to be an ecomodder's best friend. Do you guys remember ecomodder's good friend?
This site sells champagne sign vinyl, but I am not sure how close the color is, and I only saw rectangles. They sell foot-wide sections by the yard. Perhaps their gold would look close enough: http://shop.skhouston.com/Gold-Glitt...nyl-NV-127.htm
There are a few other aero modifications that I would like to try and I have long wanted to get a trailer hitch, carrier box, and extend my trunk, but it would take a great deal of work to get my Accord to return the mileage that my Civic (with failing compression) yields mostly stock.
Last edited by Xist; 01-06-2018 at 05:31 PM.. Reason: For some reason, I was using the web on my phone, while holding my laptop.
Old 01-07-2018, 05:03 PM   #18 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Hit 50 MPG in the accord!
Highway commute will be back momentarily, so I will have the chance to. The only mod I have been thinking about lately is brake drag reduction springs. I've got a massive pile of bicycle spokes saved up just for that.
As for CBR 250, it sure would be nice to hit 60 MPG, it may be possible now that I have a taller rear sprocket. The 250 also desperately needs the carbs balanced, that should allow the engine to drop to idle immediately when I pull in the clutch, instead of dicking around at 3000 rpm for 10 seconds, then dropping.
For my VFR 400, I need to do a tank first! I can assume the mileage on this bike will be as good as the CBR's if not better. It is much less of a racy engine, has taller gearing, and potentially better aero. Its actually got a fork deflector built into the front fender, CBR just has a little bikini fender.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 01-07-2018, 08:09 PM   #19 (permalink)
Though I am favorable to water + alcohol injection, do you think getting rid of the intercooler would effectively lead to some actual enhancement?
Old 01-08-2018, 12:01 AM   #20 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
From the testing I did last summer I seen a 4 to 5% increase in fuel mileage by passing the inter-cooler. Plus when the ambient temps drop during the fall it help even more.
