Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 01-28-2012, 11:45 AM   #111 (permalink)
The problem people are having is the stock OEM PCV system is "closed loop" system, meaning any blow-by gases are not allowed to get to atmosphere .
Since OEM and dyno-valve both are connected to stock intake PCV hose, the max vacuum that can draw blow-by is the same .
This vacuum issue, I can only imagine is slightly lower vacuum at idle conditions as this is were blow-by is generally low, vacuum is high and throttle is low % .
So here I can see if might be able to maintain slightly higher vacuum conditions . how much that affects anything, I don't know. also in affect if adjusted(closed position) to much you might not get enough draw at idle .
does dyno-valve use pressure sensor on crankcase vacuum so it maintains decent amount . you never want to see pressure as this can lead to leaks .
Edit: I forgot to mention modern EFI that has DBW and MAF sensor will keep monitor on any airflow that bypasses throttle body as compared to old carb, throttlebody or even speed density FI systems .
So I have hard time seeing were this would help on modern systems .
Old 01-28-2012, 07:02 PM   #112 (permalink)
The Dynovalve is a multi stage vacuum valve and is also made to modulate by a microprocessor.
Blow by gas is undetonated fuel left over from the explosions in the combustion chambers and very explosive.
Can you get more fuel efficiency from recirculating these unburned fuel/ blow by gases more efficiently and a cleaner burner from burning away these emission gases?
Would it be possible?
Old 01-28-2012, 07:10 PM   #113 (permalink)
I've heard records that skip over and over again too.
Old 01-28-2012, 08:01 PM   #114 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
OoooOOOOooo!!! You control a valve with a microprocessor! We're soooooooooooooooooo impressed!
Not.
Which is why a stock PCV valve will slam shut automatically if there's a backfire. It won't ignite those blowby gases if the engine backfires. No microprocessor needed.
Yes, it's very possible. The method currently used to do this exact thing is called the positive crankcase ventilation system. You might know it as PCV.
So... How again does your magic doohickey manage to make an internal combusion somehow develop a 25% improvement in fuel economy?
Old 01-28-2012, 10:08 PM   #115 (permalink)
...beats walking...
REMINDER -- in this forum: "...extraordinary claims require extraordinary evidence..."
Old 01-28-2012, 11:49 PM   #116 (permalink)
PCV valves were required beginning in 1963 If memory serves me right. Dang if those blow by gasses were so explosive, why have I not seen any crankcase explosions. I guess the manufacturers must post a no smoking sign next to the dipstick.
The one in the car not the one in this thread .
regards
Mech
Old 01-29-2012, 04:25 AM   #117 (permalink)
My way is the low way
Superturnier's Avatar
MyoldFord - '65 Ford Taunus 20M Turnier
90 day: 27.59 mpg (US)
Plastic Spaceship - '94 Renault Espace
90 day: 24.03 mpg (US)
Sussu - '82 Suzuki Alto
I suggest that Savicorp should send a free dynovalve sample to one of the active ecomodders for testing.
It's the only way to convince us that it saves fuel.
I definitely will not spend a 400$ for a system which will do the same recirculation as my present system does.
By the way, savi means clay in my home language.
Summer vehicle
My dad's tire pressure is much higher than your dad's!
The Following User Says Thank You to Superturnier For This Useful Post:
mcrews (02-03-2012)
Old 01-29-2012, 08:34 AM   #118 (permalink)
regards
Mech
especially since any unburnt fuel would mix with the cloud of crank case oil mist that happens when engine is running .
Old 01-29-2012, 12:29 PM   #119 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
I think it's time to introduce:
The Following User Says Thank You to jakobnev For This Useful Post:
mcrews (02-03-2012)
Old 01-29-2012, 12:48 PM   #120 (permalink)
Non empirical evidence and data... just Dynovalve Testimonies
[link removed by admin]
