Old 06-13-2008, 08:56 AM   #1 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Hatch Wing on 2009 Toyota Matrix
http://www.motortrend.com/roadtests/.../photo_01.html
Is this little rear wing going to help or hurt the cd?
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 06-13-2008, 09:20 AM   #2 (permalink)
It looks like the spoiler is higher than the roof. If this is the case then it is bad for aero.
If you look at the 03-07 Matrix you can see that the spoiler on it follows and extends the taper of the roof line. That type of spoiler helps aero.
Old 06-13-2008, 10:00 AM   #3 (permalink)
yea...I'm THAT guy
SL8Brick's Avatar
Very true, but this one is aweful for FE:
1999 Audi A6 Avant Quattro - 2.8ltr 30v V6/Automatic - 149k miles
1993 Volvo 240 Wagon - 2.3ltr SOHC/Automatic - 323k miles
Old 06-13-2008, 12:43 PM   #4 (permalink)
Wicked Wanda - '99 VW Beetle GLS
90 day: 29.59 mpg (US)
Green Monster - '99 Ford Explorer Sport
90 day: 16.73 mpg (US)
Dad's Taxi - '99 Honda Odyssey EX
90 day: 24.23 mpg (US)
The hatch on the new Matrix is more sloped than previous years. A spoiler like this probably helps since it break the airflow away from the body in a straighter line. That usually helps Cd.
Old 06-13-2008, 12:47 PM   #5 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Mazda Protege LX
90 day: 29.51 mpg (US)
90 day: 37.06 mpg (US)
Blaze - '17 Ford Escape
hurt
Old 06-13-2008, 01:30 PM   #6 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Nissan Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Plymouth Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
Originally Posted by 2003protege View Post
hurt
It would probably help if the spoiler was slightly modified so that its angle would slope downward as the same angle of the rooftop.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 06-14-2008, 12:56 PM   #7 (permalink)
upswept rear wing
Hurt.
Old 06-14-2008, 02:05 PM   #8 (permalink)
So far, the 'Hurt' vote seems to indicate that Toyota made a mistake on this one.
To this total novice aero DIYer, that looks like a wing for putting down pressure on the rear wheels. At the cost of a lot of drag.
edit:
Good news. I checked their site, and the "Hatch-mounted roof end spoiler" is not standard on the less expensive versions..
Cheers,
Rich
Last edited by Xringer; 06-14-2008 at 02:18 PM.. Reason: Adding one line of text..
Old 06-14-2008, 02:24 PM   #9 (permalink)
drag
edit:
The Matrix body type does not generate lift.So since the up-kick on the wing would generate downforce,that type of wing becomes a solution for a problem the Matrix doesn't have.My guess is that it's a "Rally-inspired" concession to styling.If they make one ( as others have mentioned already ) that follows the original roof and side contour,that would be the one to go with.
Old 06-14-2008, 04:04 PM   #10 (permalink)
How do you know for sure it doesn't generate any lift? The profile resembles a wing shape to me. Anyway, the problem here is the perspective of the photo. It's shot from ground level giving the appearance that the spoiler tilts up. The rear edge actually winds up horizontal, or parallel to the road surface; which is what you want when breaking airflow away from the body to reduce drag.
2003 Toyota Matrix Block Heater Daox EcoModding Central 25 11-03-2012 08:59 AM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
2008 Pontiac Vibe (Record Results) RH77 General Efficiency Discussion 15 03-07-2008 10:59 AM
