06-13-2008, 08:56 AM
Old Retired R&D Dude
Hatch Wing on 2009 Toyota Matrix
http://www.motortrend.com/roadtests/.../photo_01.html
Is this little rear wing going to help or hurt the cd?
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
06-13-2008, 09:20 AM
It looks like the spoiler is higher than the roof. If this is the case then it is bad for aero.
If you look at the 03-07 Matrix you can see that the spoiler on it follows and extends the taper of the roof line. That type of spoiler helps aero.
06-13-2008, 10:00 AM
yea...I'm THAT guy
Very true, but this one is aweful for FE:
1999 Audi A6 Avant Quattro - 2.8ltr 30v V6/Automatic - 149k miles
1993 Volvo 240 Wagon - 2.3ltr SOHC/Automatic - 323k miles
06-13-2008, 12:43 PM
The hatch on the new Matrix is more sloped than previous years. A spoiler like this probably helps since it break the airflow away from the body in a straighter line. That usually helps Cd.
06-13-2008, 12:47 PM
EcoModding Enthusiast
hurt
06-13-2008, 01:30 PM
Weight Reduction
4x4 - '06 Nissan Altima 2.5 Special Edition 90 day: 29.04 mpg (US) Mom's Van - '99 Plymouth Voyager SE 90 day: 25.62 mpg (US)
Originally Posted by 2003protege
hurt
It would probably help if the spoiler was slightly modified so that its angle would slope downward as the same angle of the rooftop.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
06-14-2008, 12:56 PM
upswept rear wing
Hurt.
06-14-2008, 02:05 PM
So far, the 'Hurt' vote seems to indicate that Toyota made a mistake on this one.
To this total novice aero DIYer, that looks like a wing for putting down pressure on the rear wheels. At the cost of a lot of drag.
edit:
Good news. I checked their site, and the "Hatch-mounted roof end spoiler" is not standard on the less expensive versions..
Cheers,
Rich
Reason: Adding one line of text..
06-14-2008, 02:24 PM
#9 (permalink)
drag
edit:
The Matrix body type does not generate lift.So since the up-kick on the wing would generate downforce,that type of wing becomes a solution for a problem the Matrix doesn't have.My guess is that it's a "Rally-inspired" concession to styling.If they make one ( as others have mentioned already ) that follows the original roof and side contour,that would be the one to go with.
06-14-2008, 04:04 PM
#10 (permalink)
How do you know for sure it doesn't generate any lift? The profile resembles a wing shape to me. Anyway, the problem here is the perspective of the photo. It's shot from ground level giving the appearance that the spoiler tilts up. The rear edge actually winds up horizontal, or parallel to the road surface; which is what you want when breaking airflow away from the body to reduce drag.
