Old 11-04-2010, 11:37 AM   #11 (permalink)
No, they don´t call the government efforts crazy. They say, that we will save our planets with it. haha
But cars produce much CO2 and we can reduce a lot with the modification, so...
Additionally, 1l 95 gas cost 2 Dollars.
Sorry, what does "blew out the transmission" mean?
The inspections are all 2 years. If the police find modifications on your car, which the TÜV hasn´t registerered, you have problem.
Old 11-04-2010, 12:29 PM   #12 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
It sounds like you have a much more restrictive government then we do. As long as the mods do not change the engine or drive train the emissions will be the same. I would think that modding the hub caps for pizza pans should not even questioned.
Look at what Piwoslaw did. I am no expert on the EU but is he not under the same rules as you?
Old 11-04-2010, 12:53 PM   #13 (permalink)
It´s germany.
Germany spend 70.000.000.000 Dollars for solar and it produces only 0,5% of our electricity. Reducing CO2 by modifing cost not so much.
Does poland have a "TÜV"? Denmark for example doesn´t have one.
I asked my father again and he said that all things (the pizza pans too) have to be registered. I only can delete things.
I can ask the "TÜV" tomorrow.
Now, i can post it.
http://www.spritmonitor.de/de/detailansicht/422125.html
It needs 37,63mpg
Old 11-04-2010, 01:04 PM   #14 (permalink)
37.6 isn't bad, but its not great either. With changing your driving style a little you can probably hit near 50 mpg. Check out these tips:
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
Old 11-04-2010, 01:26 PM   #15 (permalink)
I have read many tips of saving gas, but no hypermiling tips/your tips.
I will see what i can do.
Old 11-04-2010, 01:45 PM   #16 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Germany isn't very restrictive, but like most of the EU it's highly regulatory.
While you can modify your car, a lot of parts you mod it with need to undergo testing and approval before you can take them out on the streets.
And that gets pretty expensive for a one-off part.
Old 11-04-2010, 01:47 PM   #17 (permalink)
Wiki Mod
Could you make a mod, use it and remove at inspection time?
Old 11-04-2010, 01:54 PM   #18 (permalink)
euromodder's Avatar
You can use flat wheel hub covers (look for moon eyes, racing disc) if you have steel wheels.
They are replacement parts under EU regulations.
If you have leichtmetal wheels the commercially available hub covers won't work.
Old 11-04-2010, 01:55 PM   #19 (permalink)
Sorry, what´s "hunk"?
ok, i have steel wheels.
Can you modify your car, euromodder? Do you have a "TÜV"?
Old 11-04-2010, 02:06 PM   #20 (permalink)
Wiki Mod
Fixed fat fingers on cell phone.
Why We Have No Wind or Solar Power SuperTrooper General Efficiency Discussion 220 07-20-2011 10:37 PM
Without Clean Electricity, Plug-In Vehicles Aren’t So Hot SVOboy General Efficiency Discussion 37 10-17-2008 02:35 AM
