Old 10-21-2008, 04:16 PM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
HELP! Check engine light - Loss of power
My check engine light has been coming on in my '95 4-cylinder Chevy S10.
I believe this truck is PRE-OBD2, as I was never able to get the Scangauge to work with it. (Supposedly, it works on the 6-cylinder '95s!)
How do I get the "check engine light" code from the truck?
I have heard there is a way to jumper two of the pins in the diagnostic connection so that the check engine light flashes a certain number of times, and you get the error code that way.
How do I do this? Which pins do I jump? What else do I need to know?
Thanks in advance!
-Ben
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 10-21-2008, 05:43 PM   #2 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Grrrr
I think my truck has a OBDII-style plug, but uses OBD1 computer and info.
After reading through my Haynes repair manual, and checking out an S10 forum, I have come to the following conclusion:
The '93 and earlier have an ALDL connection. The 94 & 95 have the OBDII style connection, but don't actually HAVE OBDII, and the '96 and newer have OBDII.
It appears that the only way that I can read the Check Engine Light code is with a special reader that will do both ODB & OBDII. The local auto parts store's readers don't do that.
Grrr. - Very frustrating.
My YouTube Videos
Old 10-21-2008, 07:56 PM   #3 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
obdII connector means its obdII as far as a scan tool, or jumping pins to flash codes is concerned. its not actually obdII in the sense that some of the '96 requirements may not have been met yet.
Old 10-21-2008, 10:02 PM   #4 (permalink)
HObart's Avatar
ABSOLUTE Pig - '07 Ford E-250
90 day: 16.39 mpg (US)
Question Autozone
So........My radio tells me that they can scan for codes ( no charge ) and be more than happy to sell you the part that you need..........Never been there and don't know for sure......
Old 10-21-2008, 10:08 PM   #5 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Nope.
Scanguage doesn't work with it. Autozone's trouble-scanner doesn't work with it. It's an odd-ball!
My YouTube Videos
Old 10-21-2008, 11:30 PM   #6 (permalink)
Team Saturn
does the scan tool power up? if not is your cig lighter also inop?
Old 10-21-2008, 11:33 PM   #7 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Scantools just try to communicate with the computer and never can.
My cig lighter works fine.
My YouTube Videos
Old 10-21-2008, 11:38 PM   #8 (permalink)
Team Saturn
tried with a tech2 yet? i'd try to find a dealership thats willing to read codes for ya, ours does that much for free, if a tech2 wont communicate, then theres a dlc/ communications issue you'll have to fix first
Old 10-21-2008, 11:40 PM   #9 (permalink)
3dplane's Avatar
14 Mirage - '14 Mitsubishi Mirage DE
90 day: 68.74 mpg (US)
Ben!
Same question: when you say the scanner does not work,does it not even power up or just does not read?
OBD 2 carries its own power supply(orange wire behind plug) OBD 1 needs the scanner powered.
OBD 1 plug is square,OBD 2 plug is (trapezoid kind of) but yes the oddball year will have the new plug but actually OBD 1. At the dealership it is tech 1 for the old one and tech 2 for the new stuff. I don't think it's flashable.
Barna
Old 10-21-2008, 11:55 PM   #10 (permalink)
Team Saturn
btw, i used to own a 94 olds 88. it had a OBDII style connector, worked with a tech2, and not a tech1, used OBDII codes, not manufacturer codes(OBDI style). however i dont recall if i ever had it hooked up to a generic scantool to know if that worked or not.
"Service engine soon" light on rick390 Off-Topic Tech 23 07-26-2008 11:01 PM
Pontiac Sunfire Check engine light PO440 bennelson Off-Topic Tech 2 07-07-2008 09:49 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
