Old 09-12-2019, 12:44 AM   #11 (permalink)
I found something quite interesting when poking about with Honda's K series. Turns out the engine in cars like the older Type R, TSX, Civic Si, don't actually go rich even at WOT. That's true of most stock engine maps. Honda chose instead to pull timing to prevent knock. Now, admittedly this also has a fuel economy impact, since your peak cylinder pressure is farther from optimal crank angle.
Correct, many older engines did not run rich at WOT until about 3500-4000rpm. Stepping hard on the gas is less detrimental in those cases.
Everything newer though does go rich. All of the Toyota [A/N/Z/G/U]R engines do for example.
Old 09-12-2019, 08:28 AM   #12 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I'm getting a bit off topic here, but this is in reference to engines as new as engines as new as 2015. I don't know if the revisions which got direct injection started going rich under heavy load, but that would be in the last 4-6 years.
Old 09-12-2019, 09:23 AM   #13 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Originally Posted by aardvarcus View Post
You can't talk rear end gear ratios without talking transmission gear ratios. The internet is telling me your transmission has 3.9:1 first and 0.8:1 fifth. Picking your rear end ratio to me is really about a trade-off in first and fifth, would you rather have a lower first or a taller fifth. For any other gear, you could just shift to alter the ratio but you can't go lower than first or higher than fifth.
In my experience I would prefer the 3.55 to the 4:10, as long as you don't think you will have a problem in first taking off loaded. With 3.9:1 first I don't think you will, but you know your engine/torque curve better than me. The fact that your donor vehicle is set up that way from the factory tells me it can't be that bad.
I would much rather have to downshift on the hills than to be downshifted all the time. To me a truck that drives around all the time in OD and never needs to downshift for steep hills is over-geared IMHO. It also seems you already own the matching 3.55 and would have to purchase the 4.10 front, so I would try it out before spending additional cash.
My brother said the same thing about already having the 3.55's. The donor zf trans has a 5.72 1st and .76 od with a 5.24 reverse. Either way I get the best of both ends, lol. 3.55 it is. I'll have 5 gears in the basement after the swap if I need them.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 09-12-2019, 10:46 AM   #14 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Yea with a 5.72:1 first I would use the 3.55 without question.
I put a modified NV4500 in my 1994 K2500 Suburban which has a 5.61:1 first, the suburban came with 4.10 gears and first is way low. I will be swapping in 3.42 gears (tallest I can swap in factory diffs) when the project gets to that point.
Old 09-12-2019, 11:18 PM   #15 (permalink)
Originally Posted by royanddoreen View Post
might be a crazy thought, but can you match rpm by having two different o.d. size tires from front to back?
Makes me remind those Japanese and Korean cab-forward minitrucks with smaller rear wheels and a higher differential gear. But those were used in order to allow a lower boarding height, not to compensate for mismatching differential ratio in a 4WD version (which I have only seen on SRW and matching differential ratio). AFAIK the only 4WD applications with wheel sizes mismatching between the front and rear axle are agricultural machinery.
Old 10-07-2019, 10:31 PM   #16 (permalink)
I think, if you're using 3.55 gearing, it's easy to just shift up one gear if you really need to, and get the same towing as the tow package in final gear.
You can also play with about 12-20% of gearing difference, by adjusting the tire circumference.
Old 10-08-2019, 09:10 AM   #17 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
My vote would be for the 3.56 rear. And 3.55 front.
I assume the two speed transfer case will take care of the torque needed in 4wd.
I tow in direct drive in the trans. its less efficient than over drive but less heat in the trans.
I am all for overdrive under light to medium loads but it is not quite as efficient as the numbers would suggest in my experience with heavy loads. IMO the gears are there to use and take strain off the clutches and engine. But i like to shift.
I also like manual unlock front hubs for maneuvering in close quarters while needing low transfer case. That way i idle in low low and back trailers with my front hitch.
Old 10-08-2019, 09:25 AM   #18 (permalink)
R2 - '13 Chevy Volt
Team Volt
90 day: 20764 mpg (US)
You don't say what motor you have (unless I missed it) or how heavy you need to tow.
I have a '94 F-350 diesel with zf5 and 3.55 gears from the factory. I can pull up to about 20k gross comfortably (with intercooling) and love the gearing when unloaded. 2000 rpm @70mph. These motors will pull all the way down to 1200 rpm. I do wish my zf5 had the lower first great sometimes.
2̶0̶1̶3̶ ̶V̶o̶l̶t̶ ̶-̶s̶p̶o̶r̶t̶i̶n̶g̶ ̶s̶e̶a̶s̶o̶n̶a̶l̶ ̶g̶r̶i̶l̶l̶ ̶b̶l̶o̶c̶k̶
2013 Volt- wife wanted one too. Bye Leaf
2017 Volt Gen2 Red like all cars should be.
1997 Landcruiser (Bruiser) -sadly gets about 11.5 MPG...
Old 10-10-2019, 09:44 AM   #19 (permalink)
My towing rig is a '96 F250 7.3L diesel automatic with a 3.55 rear differential. My travel trailer weighs in at 6000 pounds, and the truck at about 9000, totaling about 15,000 pounds which is the listed GCVWR for the 3.55 gears in that year.
If I towed more weight I'd have opted for the 4.10 gears that were available that year; but I don't, and I didn't.
My normal towing speed is about 60mph, which equates to about 1500RPM. I normally average about 14MPG towing.
When not towing on the highway, I can get about 23MPG at 55 MPH and 21MPG at 70 MPH.
I have all the power I need in the hills and dales, so am happy with the whole setup, which I've been using since I purchased it new in 1996.
Old 11-09-2019, 07:00 PM   #20 (permalink)
Team Pontiac
A little revival here...
I can't use the 4wd front axle. It's a leaf spring and the knuckles won't fit on my brother's coil front axle. I can't use leaf spring because my snow plow is mounted where the leaves/shackles go. I guess it's more 2wd this year until I can find chevy knuckles.
1991 F-250:
