Old 04-22-2009, 11:16 AM   #1 (permalink)
90 day: 51.82 mpg (US)
Honda is developing a variable compression automobile engine: MPG up 7.4%
Source: Green Car Congress: Concept: Honda RD Developing Variable Compression Ratio Engine with Dual Piston Mechanism
In testing in an otherwise conventional production 2.0-liter, 4-cylinder engine, the dual piston mechanism was able to adjust the engine from a CR of 9.6 to 14.2 and back again. Combining the high compression ratio with the Atkinson cycle, the engineering team demonstrated a 7.4% improvement in fuel economy in operation over the Japanese 10-15 cycle.
They realized the movement of the dual piston mechanism by inertia and external hydraulic pressure, with the result that...
...in contrast to the complexity, size and power demands of earlier VCR concepts, [Honda engineer] Kato said, the new dual piston VCR could be installed without changing any of the major parts of the engine such as the engine block.
  • The ratios are set at "high" and "low", though, not a range between the two.
  • The engine was durability tested to 1 million cycles.
  • Honda sees an efficiency advantage to this approach vs. turbo/supercharging a smaller displacement engine.
  • Details are available in an SAE paper on the subject, presented at the SAE 2009 World Congress
Old 04-22-2009, 11:32 AM   #2 (permalink)
SAAB did one many years ago but it seemed to me to be really complex.
Old 04-22-2009, 11:37 AM   #3 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Volkswagen Rabbit S
90 day: 33.97 mpg (US)
There is a Veedubber in Cali that made an experimental one in his garage like a decade ago
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 04-22-2009, 11:42 AM   #4 (permalink)
Manic Rabbit
Southcross's Avatar
ok... correction, has been working on it for a Decade in his garage LOL
Amazing Engine, Amazing Pizza! at TimboTrip.com
-Edward
Goal: 4x / 5x
Old 04-22-2009, 12:16 PM   #5 (permalink)
Anyone have any images of the principle of the idea?
I could see this being easy on a two stroke type engine just having the head with a moving part in it that would take up some combustion chamber, but with valves in the way....
Old 04-22-2009, 01:10 PM   #6 (permalink)
Frank: didn't SAAB's use a movable head somehow?
rkcarguy: no image, but a pretty good description from the GCC article:
The piston structure has an inner and an outer piston. The outer piston sits atop the inner piston, and constitutes the combustion chamber against a cylinder head; the inner piston has the function of a piston skirt, a lifter mechanism, and a lock mechanism....
Honda installed a small pump separate from that of engine lubricating oil pump. Oil passage was constructed from the external pump through the crankshaft and connecting rod to the piston.
To switch from low to high, the hydraulic pressure is turned on. This acts on the pin of a lock plate, freeing the outer piston. The outer piston rises the 3.5 mm by the resultant force of the piston inertia force and the cylinder pressure force. To go from high to low, the hydraulic pressure is turned off, the lifter plate rotates out, and the out piston lowers over the inner piston by the resultant force.
Old 04-22-2009, 01:15 PM   #7 (permalink)
I do remember hearing about the SAAB engine a long time ago. Here is a link:
http://www.saabnet.com/tsn/press/000318p.html
Glad to see the issue being revisited. 7.4% is nothing to sneeze at.
Old 04-22-2009, 01:38 PM   #8 (permalink)
Description works for me metrompg. Looks like it's VTEC pistons
VTEC activates a solenoid which pressurizes the pivot point of a 2nd set of rockers under a larger cam lobe, pretty ingenious.
Old 04-22-2009, 01:45 PM   #9 (permalink)
Manic Rabbit
Southcross's Avatar
I could see valve timing be used to increase and decrease "trapped" compression
-Edward
Goal: 4x / 5x
Old 04-22-2009, 01:57 PM   #10 (permalink)
VTEC for pistons - good analogy!
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Someone asks: How did I get 40 mpg (US) from an '89 Honda Accord? MetroMPG Hypermiling / EcoDriver's Ed 0 04-09-2009 05:52 PM
Variable compression engine reduces fuel use 30%? SVOboy General Efficiency Discussion 6 01-02-2009 09:10 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
