Old 08-11-2012, 03:51 PM   #491 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
I just rode over 500 miles just last week, up to northern Wisconsin and back. Its probably as rare as an Insight with a tail cone.
crazyguyonabike.com: Bicycle Touring: Back to the Door, by Anthony Levand
Originally Posted by Varn View Post
You're the man Tony. Thousands of miles in your streamlined bike. Do you realize how rare that is?
I had a Renault R5 that would get lots of oversteer on trailing throttle. Quite disconcerting if you have to let off into a turn.
- Tony
The Following 2 Users Say Thank You to arcosine For This Useful Post:
aerohead (08-11-2012), wyatt (10-05-2012)
Old 10-04-2012, 08:17 PM   #492 (permalink)
I'm curious to know what the real world mpg difference has been. Did I miss that in this thread?
Old 10-04-2012, 10:06 PM   #493 (permalink)
It is a very long thread! He has measured about an 18% improvement in FE at 56MPH.
http://ecomodder.com/forum/showthrea...tml#post224037
http://ecomodder.com/forum/showthrea...tml#post203904
He already has an excellent full belly pan on the car:
http://ecomodder.com/forum/showthrea...lly-10638.html
aerohead (10-05-2012)
Old 10-05-2012, 01:35 PM   #494 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Thanks Neil.
I saw the question last night just before turning in for the evening.
Jim.
Old 10-05-2012, 02:17 PM   #495 (permalink)
BikerModder's Avatar
Deedee - '09 Smart ForTwo Pure 999cc
90 day: 47.39 mpg (US)
How's the heater in those things I wonder, they look a lot of fun to drive.
Old 10-06-2012, 09:22 AM   #496 (permalink)
3-Wheeler's Avatar
If you keep an eye on the radiator block, it's not bad.
The engine puts out so little heat when your eco-driving, that the radiator block setting becomes very important to:
1) Maintain engine heat/engine warm up time
2) Keep the cabin warm
The car is definitely warmer than the motorcycle, which I was riding for the last two weeks, while refurbishing the Insight battery pack!
An automatic radiator block would be a great addition to the car someday.
Jim.
Old 10-06-2012, 09:35 AM   #497 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Do you even need it open at all? Unless I go on trips of 2 hours or longer mine has stayed closed 100% .
Old 10-06-2012, 09:37 PM   #498 (permalink)
3-Wheeler's Avatar
I'm not sure, but I think you are referring to the grill block?
If this is the case, then whether the grill block is closed or not, this depends entirely on the outside air temperature.
If it's summer time and hot out, and I'm heading to LaCross, well then I have the cardboard completely removed. This because going up the "bluffs", I have seen coolant temps at 213F, which is way hot. The fan kicks on at 205F.
On the other hand if it's winter, then I have strip about 2 inches wide open in the cardboard.
An automatic grill block would take care of all this.
Jim.
Old 10-07-2012, 10:04 AM   #499 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
That's because you pulse 'n glide like a madman! I'm guessing 3-Wheeler doesn't P&G as aggressively.
-Terry
Old 10-07-2012, 03:42 PM   #500 (permalink)
Honda modder
civruck - '88 Honda civic lx
My foam technique
Originally Posted by 3-Wheeler View Post
The two tail light mounting brackets are getting "angled" blocks attached to allow through bolts to rest at these angles.
The first piece of foam is attached to one of the supporting embedded wood anchors. I'll have to admit, that this was pretty exciting seeing the very first foam piece in place.
Here's the back side of the foam, showing just how the embedded wood block is being supported.
Later that night, a picture with the garage door closed, since the mosquitos are out and hungry. The foam has a nice and tight fit against the sheet metal. Way tighter than the normal gaps around the doors and such.
Here's another shot several days later. It took about two hours to fit and glue that curved piece on the bottom side of the tail light. It's the piece with the masking tape and duct tape attached. This includes both sides of the car. The block is extremely thin on the back side due to the way the sheet metal is formed in that area.
This picture is showing the underside of the bumper area. Lots of foam blocks added here.
Those four foam blocks that are added to the bottom of this picture, will create some of the hardest work on the tail extension project. They are so innocent looking but the shape in this area is very difficult to keep true to the Honda stylist's intentions.
Here's a shot of the back side of the foam thus far. Lot's of Elmers Glue back there!
Now the assemblage of foam is removed from the car, and you can see the detail of foam shaping that went into each block before being glued. This is the summation of many hours of cutting, fitting, and gluing each individual block.
Here is what the underside blocks look like so far. You can see the embedded wood support blocks in the foam here as well.
Here's a close-up, showing the many various shaped blocks that make up the assembly.
Now fiberglass cloth/resin is added to the back side of this assembly and placed on the car to setup.
Notice the Glad Wrap sticking out from behind the foam. This acts as a mold release to keep the epoxy from sticking anywhere on the car.
Here's several more blocks added along the rear skirt.
This shows the back side of the assembly with the fiberglass and Glad Wrap still attached.
Same thing for the lower assembly, and still with mold release attached.
This shows the curvature template that will be used extensively in an attempt to maintain proper curvature of the tail extension.
This is a "machined" piece of foam, using a "new technique" that was necessary to keep the intended Honda shape just above the rear skirt.
This picture shows the new machined foam smoothed out and added to the rest of the foam in this area. The foam template is used to glue each piece and then rechecked several more times to ensure that the angles are correct before allowing the glue to setup.
Notice the white filler. These are areas that were over-filed/sanded and had to be filled to bring these surfaces in alignment with the template. The white areas took the most time to ensure they are "straight" and smooth.
This is a picture as the car is today. Lot's of hours at this point!!
You can see the older fiberglass area and the new panels that were added more recently.
The end shot shows the "curvature" of the sheet metal shape just above the rear skirts. This area really takes patience to get right and the convex and concave shapes "look" extremely simple, but actually have compound radii. This takes the most planning and care to keep aligned with the sheet metal shape in this area.
These panels have enough foam added now, that more fiberglass will be added to support the back sides of these panels, before other blocks are again added.
The masking tape on the car is used to "align" the template in the same direction as the anticipated air flow across these surfaces. This also allows some repeatability in placement of the template each time it is used to glue more blocks behind those already in place.
Jim.
See photo, spruce 2" x 4" x 5' , gorilla glue. use flat surface of foam
as much as possible as shaping is a lot of work and weight. Cover
with cheese cloth and latex paint, watch out for curbs, speed tested
to 90 mph, 91 crx-hf, all bolt on
Name:	1-photo reload to new hp laptop 9-12-2011.jpg
The Following User Says Thank You to darrylrobida For This Useful Post:
NeilBlanchard (10-07-2012)
FS: All USED Honda Insight Parts For Sale Fabio For Sale 17 06-16-2013 02:49 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Designing a tail extension for the first-gen Insight RobertSmalls Aerodynamics 187 07-11-2010 10:44 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
