03-17-2020, 03:11 PM
#491 (permalink)
Update! Engine kill switch complete.
I decided to use the power steering signal, as it's unused in the Insight - this input is for the RSX's hydraulic PS. The way I set it up is as follows:
-Shifter button grounds EPS input
-ECU nitrous control #1 activates
-Nitrous control #1 adds negative 600 fuel units to the fuel map
-ECU momentarily activates the A/C compressor to stop the engine more quickly
03-19-2020, 07:39 PM
#492 (permalink)
The Following 6 Users Say Thank You to Ecky For This Useful Post:
03-19-2020, 09:58 PM
#493 (permalink)
Luddite
Wonderful! A perfect 2 seater car!
The Following User Says Thank You to deluxx For This Useful Post:
03-20-2020, 10:34 PM
#494 (permalink)
Cyborg ECU
They look great. I wonder if instead of two screen mounted on the dash, if you ever considered one of those windshield mounted rear view mirror screens.
03-21-2020, 07:07 AM
#495 (permalink)
I have, and even tried mounting one or both screens up there. I didn't like the sensation of turning my head right to look for a left hand turn.
03-21-2020, 11:18 AM
#496 (permalink)
Ecky, you said New cameras! I like them a lot better than the old ones. What is the viewing angle of the new cameras? I have a passenger side camera that has a viewing angle of 170 degrees, and I don't find it very satisfying. I bought one that has a 120 degree angle but I haven't had the opportunity to install it.
03-21-2020, 08:12 PM
#498 (permalink)
It looks really great. What's your cruising MAP on the freeway?
03-21-2020, 09:12 PM
#499 (permalink)
I get around 380-400mbar at 55mph, 450mbar at 65mph. I want to say idle is ~250mbar so that's what, 20% and 25% load?
03-21-2020, 10:26 PM
#500 (permalink)
Wow that's low, next mod external EGR? Easy implementation would be a valve that's manually actuated via a pushrod/cable going to the cabin, sized for cruising. I believe it should help a good amount.
My feeling is that ignition timing isn't going to be too critical since the hotter IAT speeds up combustion.
The Following User Says Thank You to serialk11r For This Useful Post:
