10-05-2020, 10:04 AM
#571 (permalink)
Originally Posted by minor4326
wouldn't it be just as easy and cheaper to put a timer on the heater and run it 2-4 hours before work?
Previously I had experimented with a block heater and the stock 1.0L engine, and found there was very little gain running the heater for more than 2 hours, and that it's overall diminishing the longer you run it.
I actually just purchased a cheap outlet timer from Amazon. This morning was the first time I used it, and I started the heater 1 hour before my normal departure time. I found that the coolant reached ~160F (basically lower end of full operating temperature) around the same time as it would normally just be hitting 120. And, that was with interior heat running.
If I were to guess, the break-even in electricity costs is likely sometime between 1 hour and 2 hours of heating.
10-05-2020, 10:09 AM
#572 (permalink)
Originally Posted by Piotrsko
Not necessarily. Large current timers are about $70 USD, and 2-4 hours may not be enough time to warm things enough to buy economy
The current isn't too high. If I recall, standard Honda block heaters are 400w?
I might later add oil pan and transmission pad heaters.
10-06-2020, 09:53 AM
#573 (permalink)
Thanks for the clarification. All the heaters I have used require special stuff rated for 20 amps or 2500 watts or they start fires.
11-22-2020, 03:59 PM
#574 (permalink)
 Sounds really interesting. Would a 2.0 liter engine from a 2002 to 2006 Honda Civic Si fit ?
11-22-2020, 04:15 PM
#575 (permalink)
1st Gen Insight
I am new to this . Thank you for any knowledge you can share. I will have a 2001 Insight I plan on purchasing from the original owner. They have replaced CVT, radiator and battery pack.Car belongs to a friend of my wife. I do not know the mileage yet. Asking price is $ 5,000. I am guessing my wife’s friend has spent a good amount reconditions this car. Does this price seem reasonable.
11-22-2020, 04:31 PM
#576 (permalink)
Yes. I would personally not use the transmission though. An Accord gearbox would match an 02-05 Civic Si engine, wiring harness and ECU and give better ratios for the Insight's weight and tire size. It also bolts up to the Si engine without issue.
It's hard to find a clean, low mile Insight, and those can hold a premium, but right now they're basically rock bottom in terms of price. It's not uncommon to find many of them at $1500-2000. The CVTs are much less desirable than most because they are less reliable and get worse economy. I would say if it's really clean and less than 125k miles, I would price it at $4000.
If this friend doesn't have a receipt for the battery, treat it as if it didn't happen. No receipt, no warranty, and aftermarket batteries don't last nearly as well as the original OEM did.
02-11-2021, 08:33 PM
#577 (permalink)
Been a little while since I updated. I haven't been driving super economically, but it's also somewhat dispiriting to struggle against the effects of winter.
I just ordered a new crank pulley, and am waiting on the belt to arrive. I'll be swapping the factory K24 pulley out for a Type R / K20Z1 pulley, which is 12% smaller, and will similarly underdrive my water pump, alternator, and A/C compressor by 12%. I'm thinking it should help get my parasitic losses down a bit.
Hopefully it will also be an upgrade in damping, since it's brand new, whereas the other pulley is ~2004-2008.
The mass is not much different between the two, but the smaller diameter should also give a smaller moment of inertia, helping the motor rev more quickly.
02-11-2021, 10:44 PM
#578 (permalink)
I realize I haven't shared many videos. Please be aware that I meticulously follow (or greatly fall short of) speed limits, except for when I occasionally open it up for a few seconds on a back road.
02-11-2021, 10:45 PM
#579 (permalink)
Not exactly eco-friendly. I'll make a video of eco-driving with the K series sometime.
02-11-2021, 11:08 PM
#580 (permalink)
Growin a stash
Holy crap that's fast. What is that, like 3s to 60?
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
The Following User Says Thank You to ME_Andy For This Useful Post:
