Old 05-11-2020, 10:30 PM   #21 (permalink)
Originally Posted by 19bonestock88 View Post
So I’ve started with the vent installation, and it’s been a huge undertaking. Having to cut out a lot of the bracing to make the vents work. The hood should still be fine, as it basically had most of a second skin underneath it, and it was much heavier than the sedan hood I had before. I replaced the prop rod with a pair of gas struts, partly because I had them with the hood before, and partly because I’m going to have to cut the prop rod hole out for the center vents. I ran out of reinforced cutting wheels, so further progress is either going to be painstakingly slow or I’m going to buy more wheels.
Looking good!
Old 05-14-2020, 02:18 PM   #22 (permalink)
Did I miss something? Where are the test results discussed?
Without any testing, IMO, this is just mainly becomes a "Cosmetic" exercise.
I also would have suggested for this application a differential pressure gauge be used, to find the aero sweet spot faster, ie two tubes measuring inner and outer pressures at the same time, and conditions.
Old 05-14-2020, 05:11 PM   #23 (permalink)
Hell no, why would any one want to do that? After all, it's only 16 years since I first (as far as I know) published on the web how amateurs could use this technique.
https://www.autospeed.com/cms/a_113178/article
At least some people did suggest in this thread that he do some pressure measurement, so I suppose there is progress!
