Old 01-05-2008, 01:42 AM   #11 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
A big old heat sink? Something like a WVO heating system but just for the coolant to wrap around the exhaust?
Old 01-05-2008, 01:47 AM   #12 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
cut a pop can in half and clamp it to the tail pipe with a small hole about the size of a quarter in it
use a clamp though and not duct tape or it wont be on there for long...
From what my camaro ran like during the brief time I had restrictors duct taped over my exhaust it made it run good at low rpms. The other guy who tested them noticed his car warmed up a lot faster with them on. I think the main benefit would be just the improved warm up time so the hole just needs to be small enough to give a slight back pressure to help build up some heat.
I might test this out if it gets cold and stays that way around here. But tomorrow it is back into the 50's
Old 01-05-2008, 01:53 AM   #13 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
I was thinking that too.... But once you're warmed up - you're faced with a crap ton of extra heat being added to coolant as it enters the block...
Something like that - just regulated such that it can be turned off...
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 01-05-2008, 01:56 AM   #14 (permalink)
Dartmouth 2010
SVOboy's Avatar
Well, use a solenoid with a switch, just like a WVO conversion eh? Or even a temp switch that bypasses the exhaust portion at ~170.
Old 01-05-2008, 01:59 AM   #15 (permalink)
MechE
Perhaps I should read up a bit more on the WVO heat exchangers (I've only seen coolant type exchangers - does an exhaust type exist?).....
I'm not trying to be completely negative - just pointing out what I think are obvious problems in thought.... Do you think there'd be a problem with the isolated coolant boiling off (in general, causing pressure issues)?
Old 01-05-2008, 02:01 AM   #16 (permalink)
Dartmouth 2010
SVOboy's Avatar
No no, no exhaust type...I mean the coolant type but I set up the analogy badly...In our case the WVO would be the exhaust and instead of heating it we're stealing heat from it.
It's definately an issue. I think we'd have to worry about how hot the exhaust gets...I'm assuming pre-cat...Where does coolant boil at?
Old 01-05-2008, 02:26 AM   #17 (permalink)
MechE
Depends on concentration of antifreeze, antifreeze type and pressure... But I've seen 50/50 mix @ 15psi brings the boiling point to ~275F (number floating around on the interwebs)... Which AFAIK is below precat temps...
Old 01-05-2008, 02:31 AM   #18 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Heat exchangers are a PITA IMO, like Coyote X said restrictions are the way to go. Old domestics had a spring/flap on the exhaust for warm up, old skool internal EGR I guess. The flap would stay closed'ish and not all the hot gas would exit the combustion chamber until the manifold warmed up enough/the spring rate dropped enough and the flap popped open.
Edit- What about one of those cable actuated exhaust cutouts?
Old 01-05-2008, 09:16 AM   #19 (permalink)
I think a block heater would be cheaper than most of the suggestions thus far.
Old 01-05-2008, 09:33 AM   #20 (permalink)
MechE
It's not an option for anyone that isn't near a plug :/
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 63 03-22-2019 09:53 AM
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 03:39 PM
