View Poll Results: How often do you top off your cars battery?
daily 7 43.75%
every other day 2 12.50%
weekly 4 25.00%
never 4 25.00%
Pulse and glide + engine off coast 7 43.75%
DCFCO + Neutral Engine on Coast 1 6.25%
Multiple Choice Poll. Voters: 16. You may not vote on this poll
Old 12-08-2014, 10:50 AM   #1 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
How many that P&G have a low battery?
I use P&G alot. My battery / Alternator suck.or maybe nott?
How many others cars cant keep the battery upto charge when you P&G alot?
If I have a highway exit soon I will have to idle in neutral to charge the battery before i have to keystart at a red light I will get caught at down the road.
Now I charge it Like every other day. how often do you charge your cars battery?
Old 12-08-2014, 10:58 AM   #2 (permalink)
I keep an eye on my voltmeter and top it off as needed. This seems to be almost every day. I could probably get away with every other day, but I think that would effect my battery's life, and I'd like to keep it healthy as long as possible.
Old 12-08-2014, 11:07 AM   #3 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
I never charged the battery once in the Black Widow, and I P&G-ed and EOC-ed non-stop for months on end. I also go to work well before daylight, so mornings I would be doing it with the headlights on. Not once did it ever fail to start, so I'd say you have a weak battery, alternator, short, loose starter wire, etc . . . .
Eventually I bump started pretty much 99.5% of the time, and only when I was unfortunate enough to actually have to stop did I ever key-start. I'm sure that had something to do with it staying relatively charged, but if you're bump starting most of the time, there's a problem with your charging system somewhere
My kid is also doing a lot of EOC & P&G in the Black Widow these days, and he's never had a problem either.
Old 12-08-2014, 11:21 AM   #4 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
Yes old KIA's are infamous for having crap alternators and crap brakes..
Every time i bumpstart I get a loud CCCRRKKKKRKRCCCKK from the alternator.
The other day I went in the under ground tunnel and it was funny having it squeak everytime I did a bumpstart up the hill. the tunnel is like this U
I also have a radio and power windows taking battery.
And many many traffic lights in maryland. I take the highway as much as possible tho#!
Old 12-08-2014, 12:03 PM   #5 (permalink)
grey panther - '02 Mercury Grand Marquis
Team Panther
90 day: 27.15 mpg (US)
I have an automatic so I don't engine off coast except to coast to a full red light.
I use a 1.8 amp solar charger
Old 12-08-2014, 01:15 PM   #6 (permalink)
90 day: 51.82 mpg (US)
I keep solar panels on the car as well, and since I don't drive daily, it's a decent solution.
But at this time of year (cold), battery performance is already degraded, so I do a lot less P&G or coasting with the engine off. Or if I'm on a long enough trip, I do much less engine-off toward the end of the trip to ensure I park the car with a decent state of charge in the battery.
Old 12-08-2014, 03:18 PM   #7 (permalink)
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
I do a lot of EOC coasting (up to 20% of tank miles). Last summer I noticed my volt gauge showed 10.8 volts at the end of a very long EOC (lights on).
After that I started "trickle" charging twice a day with a 3.3 amp CTEK charger. I charged overnight and also once I got to the shop. It took about 2 hours each time to charge the battery back up. I noticed about a 3 MPG pick up from this procedure, because the alternator was not charging as much while driving.
This is what got me looking at adding the alternator delete on the red 92 VX.
Old 12-08-2014, 03:26 PM   #8 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Watching your voltages with the sg? If so, what are you seeing? I don't do a lot of eoc'ing, so more of my observations are short term. I've noticed holding my brake drops my voltage surprisingly fast (lights up 7 bulbs), faster than having headlights on at night for me, so using parking brake or shifting to park helps at longer lights
Old 12-08-2014, 04:16 PM   #9 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I trickle charge overnight daily in winter, and weekly in summer.
Old 12-08-2014, 05:25 PM   #10 (permalink)
Gen-1 Insights
Reply to 2000mc
I have a MPGuino but also have an aftermarket digital voltage gauge (I am an information geek). Usually the gauge would sink to 11.7 volts on a long EOC, but finally it dropped lower and I knew I was putting a real strain on the battery.
So far the water and oil pre-heat and the alternator delete have allowed me to maintain the same MPG I was getting last summer.
