08-02-2014, 07:09 PM
#101 (permalink)
herp derp Apprentice
Originally Posted by CargoBoatTails
The recommended tire pressures on the Vehicle Certification Label in the door are simply so that tires wear evenly.
Simply for tire wear, is how I read it
08-02-2014, 07:10 PM
#102 (permalink)
The recommended tire pressures on the Vehicle Certification Label in the door are simply so that tires wear evenly. Over inflated tires will wear the center faster and underinflated will wear the shoulders faster. The ideal choice is to use the smallest possible tire(max load=GAWR/2) with the highest tire pressure so they wear evenly. A good example of this was on the poorly engineered Audi Cabriolet S Lines which weighed a few pounds shy of 2 tons and recommended 46 psi in 40 series tires.
About 120,000 miles of tires at 45 PSI and not any uneven wear, on several different tires and cars-trucks running higher pressures for a decade. In fact based on my experience the tires will last longer, as well as the brakes and most other vehicle parts from hypermiling.
regards
Mech
08-02-2014, 07:11 PM
#103 (permalink)
Yeah, after all the other criteria is met.
08-02-2014, 07:12 PM
#104 (permalink)
regards
Mech
I can take a picture of all 4 of my tires worn in the middle at 46 psi.
08-02-2014, 07:28 PM
#105 (permalink)
LOL, you need to go around corners faster.
regards
Mech
The Following 3 Users Say Thank You to user removed For This Useful Post:
08-02-2014, 07:40 PM
#106 (permalink)
Cargoboattails- what % of your miles would you consider "highway" miles?
08-02-2014, 07:43 PM
#107 (permalink)
I couldn't say accurately, but mostly as I lived and worked off the highway. I'm also in a rural area with no much stop and go.
08-02-2014, 10:03 PM
#108 (permalink)
Just cruisin’ along
48psi.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
08-03-2014, 10:06 AM
#109 (permalink)
I run 44psig in tires that are 51psig max.
Im curious, do cheapo tires with less advanced construction techniques and materials wear the center faster at elevated pressures?
08-03-2014, 10:10 AM
#110 (permalink)
Not bad for a machine
I run 55+psi in tires with sidewall max of 44psi. A little bumpy!
