Old 08-02-2014, 08:09 PM   #101 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Originally Posted by CargoBoatTails View Post
The recommended tire pressures on the Vehicle Certification Label in the door are simply so that tires wear evenly.
Simply for tire wear, is how I read it
Old 08-02-2014, 08:10 PM   #102 (permalink)
The recommended tire pressures on the Vehicle Certification Label in the door are simply so that tires wear evenly. Over inflated tires will wear the center faster and underinflated will wear the shoulders faster. The ideal choice is to use the smallest possible tire(max load=GAWR/2) with the highest tire pressure so they wear evenly. A good example of this was on the poorly engineered Audi Cabriolet S Lines which weighed a few pounds shy of 2 tons and recommended 46 psi in 40 series tires.
About 120,000 miles of tires at 45 PSI and not any uneven wear, on several different tires and cars-trucks running higher pressures for a decade. In fact based on my experience the tires will last longer, as well as the brakes and most other vehicle parts from hypermiling.
regards
Mech
E.Roy (08-05-2014)
Old 08-02-2014, 08:11 PM   #103 (permalink)
CargoBoatTails's Avatar
Yeah, after all the other criteria is met.
Old 08-02-2014, 08:12 PM   #104 (permalink)
regards
Mech
I can take a picture of all 4 of my tires worn in the middle at 46 psi.
Old 08-02-2014, 08:28 PM   #105 (permalink)
LOL, you need to go around corners faster.
regards
Mech
The Following 3 Users Say Thank You to user removed For This Useful Post:
Mustang Dave (08-03-2014), nemo (08-02-2014), niky (08-03-2014)
Old 08-02-2014, 08:40 PM   #106 (permalink)
Team Saturn
Cargoboattails- what % of your miles would you consider "highway" miles?
Old 08-02-2014, 08:43 PM   #107 (permalink)
I couldn't say accurately, but mostly as I lived and worked off the highway. I'm also in a rural area with no much stop and go.
Old 08-02-2014, 11:03 PM   #108 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
48psi.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 08-03-2014, 11:06 AM   #109 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I run 44psig in tires that are 51psig max.
Im curious, do cheapo tires with less advanced construction techniques and materials wear the center faster at elevated pressures?
Old 08-03-2014, 11:10 AM   #110 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
I run 55+psi in tires with sidewall max of 44psi. A little bumpy!
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-26-2016 12:39 AM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 09:29 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 07:36 PM
Tires with different max PSI Goldenfrog EcoModding Central 2 06-14-2008 04:42 PM
I upped the PSI to my tires from 29 to 35 and... MartialArtist EcoModding Central 55 04-04-2008 02:20 AM
