Old 08-02-2014, 10:17 AM   #91 (permalink)
I run around 50 psi. I don't check them too often to be honest. I use 50 since IMO that gives me some leeway. I just want them to be kept above 40-45 really. Ride comfort isn't really an issue on the cars I have despite horrible Wisconsin roads. The stock springs are soft enough for me.
Old 08-02-2014, 10:57 AM   #92 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Yeah. I don't check too frequently either. Need to right now, actually. I get the times warmed up first, check, and pump them to 60 psi. That's so that cool or cold I have my best chance at staying near, at, or above 54 psi (44 recommended on the sidewalls). MetroMPG in his test--IIRC--found 10 psi over sidewall to be the point where benefits seemed to max out. Good enough for me.
Old 08-02-2014, 11:01 AM   #93 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
I'm running 55psi all around.
Old 08-02-2014, 12:11 PM   #94 (permalink)
You don't what psi your tires are until you check them. I thought i was at 55psi. Went to refill with nitrogen for the first time in 6 months and i was at 35psi. What a nightmare!
I try to be helpful. I'm not an expert.
Old 08-02-2014, 12:37 PM   #95 (permalink)
What brake pedal?
digital rules's Avatar
Silver Streak-5M - '05 Toyota Corolla S
90 day: 42.41 mpg (US)
Run 38-40 in the warmer months (the roads in DC beat the car too hard with higher psi) Run 35-37 in the colder months to keep the ride tolerable.
Old 08-02-2014, 05:31 PM   #96 (permalink)
CargoBoatTails's Avatar
The recommended tire pressures on the Vehicle Certification Label in the door are simply so that tires wear evenly. Over inflated tires will wear the center faster and underinflated will wear the shoulders faster. The ideal choice is to use the smallest possible tire(max load=GAWR/2) with the highest tire pressure so they wear evenly. A good example of this was on the poorly engineered Audi Cabriolet S Lines which weighed a few pounds shy of 2 tons and recommended 46 psi in 40 series tires.
Old 08-02-2014, 06:29 PM   #97 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
No
Old 08-02-2014, 06:35 PM   #98 (permalink)
Thumbs down
Originally Posted by 2000mc View Post
No
What's your source? Here's mine. Tire Safety and Maintenance | AAA Exchange
Old 08-02-2014, 06:46 PM   #99 (permalink)
Team Saturn
You don't think the vehicle manufacturer is trying to balance tread wear, ride quality, handling, load capacity, rolling resistance, snow and wet traction, tire/road noise? It's only a recommended pressure for tread wear?
Old 08-02-2014, 06:58 PM   #100 (permalink)
Oh did I say only?
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
Tires with different max PSI Goldenfrog EcoModding Central 2 06-14-2008 03:42 PM
I upped the PSI to my tires from 29 to 35 and... MartialArtist EcoModding Central 55 04-04-2008 01:20 AM
