Old 03-15-2009, 02:28 PM   #21 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
If you search around darin did a coastdown test and found that the improvements aren't that much when you get above 50 psi.
I run 50 all around.
Old 03-15-2009, 02:37 PM   #22 (permalink)
DMC - '99 Honda Civic DX
interesting..
The most I ever ran was 55psi in my last car. In my current car I try 40psi, sometimes I forget about it, my rear is probably around 15psi..lol
Old 03-15-2009, 02:53 PM   #23 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
Compaq888 What do you drive?
Old 03-15-2009, 03:26 PM   #24 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Firestones running at 50 psi with a sidewall max of 44psi. The uneven wear from when i got the car is still there. They were "underinflated" at 32 psi and wore more at the shoulder than the centre.
ollie
Old 03-16-2009, 12:53 AM   #25 (permalink)
Your temps have risen recently right?
Frank-
The outdoor temps during my most recent trip (a little less than 1200 mi last weekend) were actually lower than my last long trip. Last weekend, I saw outside temps of 35-55 degrees, and I managed close to 40mpg (see my fuel log). The trip before that was considerably warmer, but I had lower tire pressure and was a few MPG lower.
Old 03-16-2009, 06:46 AM   #26 (permalink)
Tire Geek
CapriRacer's Avatar
As a tire engineer, I find it very funny that if a reference pressure is mentioned, it is what is on the sidewall and not once is the placard pressure mentioned! This shows a bit of misunderstanding of the physics involved.
Old 03-16-2009, 07:08 AM   #27 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Originally Posted by 1337 View Post
tasdrouille-
Have you ever had a problem running at 60 PSI? I'm considering running 55 or 60 in my tires. I bet the ride in the city would be hell, but 95% of my driving is highway, so I wouldn't mind.
Never had a problem wear wise. Performance wise, I can't tell, but they always did the job I wanted them to perform.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 03-16-2009, 07:21 AM   #28 (permalink)
blueflame's Avatar
Ride is hell at high pressures, but my ultramicrocar is a hardriding buzz box anyway and I enjoy getting over 70mpgUS and very long EOC glides...
Which is kinda FE heaven
Old 03-16-2009, 09:21 AM   #29 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Hi,
I've read SAE Paper 800087 and it is a good source. I'm new here but was wondering if any of the members have used the coast-down test protocol to measure pressure effects on Crr?
Nothing like a little observation for cementing a good model.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 03-16-2009, 12:26 PM   #30 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
I usually keep mine at 30-35. They are rated at 44. I would go higher if Michigan had good roads. It handles much better at 40 but every pothole and every expansion joint every 100 ft is hell. I already have to replace balljoints once a year.
Winter daily driver, parked most days right now
Summer daily driver
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
Tires with different max PSI Goldenfrog EcoModding Central 2 06-14-2008 03:42 PM
I upped the PSI to my tires from 29 to 35 and... MartialArtist EcoModding Central 55 04-04-2008 01:20 AM
