Old 03-31-2009, 03:36 PM   #41 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
Originally Posted by Funny View Post
Wow, I must be the highest percentage above sidewall max here. Cooper Lifeliner GLS Tires - 35 PSI sidewall max - Currently running at 55 PSI.
That is 157% over the rating for the tire, no blowouts or unusual tire wear yet, and I've had them on the Lemon for a year and a quarter. I have hit potholes that could swallow a car, and traveled 100+ miles at a time, still no issues. Maybe I'm just lucky .
Nice! I think I'll go to 55 psi soon.
Old 03-31-2009, 04:10 PM   #42 (permalink)
Weight Reduction
Drive Stick's Avatar
Celica GTS - '02 Toyota Celica GT-S
90 day: 36.32 mpg (US)
Send a message via AIM to Drive Stick
I run 40psi on all car tires irregardless of what the tire says. My tires all wear perfectly even, across the block and I don't see a need to change this considering the roads I travel have some unexpcted obstacles that require the tires have a LITTLE give to them or they will blow out.
Potholes, etc.
Old 03-31-2009, 04:13 PM   #43 (permalink)
Actually, tires with more pressure have less problems blowing out. It is suggested by Tire Rack to increase tire pressure in spring with all the potholes.
Old 03-31-2009, 04:31 PM   #44 (permalink)
Weight Reduction
Interesting, I didn't hear that before. You may be right though, years back I was forced to eat a curb by a police officer that was about to slam into me chasing somebody and the front tire running 40 psi didn't blow out, but the rear tire running 35 did. I mean it could all be a matter of physics or it could be that the higher pressure saved the front tire.
Old 03-31-2009, 09:22 PM   #45 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Don't get me wrong, I run really over inflated tires, but some people can't stand the added road noise. I just have no problem ignoring it, though I still notice it. I always keep a properly inflated spare tire and a can of Fix-a-Flat in my car, because everyone should be a good Boy Scout and "Be Prepared".
Just because you over inflate your tires doesn't mean you can neglect them, thinking they will take care of themselves. They have to be watched even closer. Just my $0.02.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 03-31-2009, 11:56 PM   #46 (permalink)
Michelin Rainforce MX4 all seasons, 35psi sidewall. I run them at 42 in the summer and 35 in the winter. No wear or handling problems at all.
Old 04-01-2009, 01:11 PM   #47 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
I run sidewall max in all of my cars all of the time.
Currently 44 in the Metro and Avalon and 37 in the Jetta. (It came with some weird off brand tires and when they wear out we will get better ones.)
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 04-01-2009, 01:26 PM   #48 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I always run the sidewall max at the very minimum in all of my cars except in unusual weather.
My electric cars have
60psi in the van the tires are rated at 44psi
My comutacar has 60psi tires which I run up to 70psi in
My dodge crewcab usually has 50-60psi in tires are rated at 50psi
My Buick and Jetta have 40-50psi (35ish PSI rating)
I found especially on the Miles ZX40 that my range and speed improved greatly moving from 32psi up to 50psi and then to 60psi and yes I can notice a real difference in the form of an extra few MPH on the top speed.
Old 04-02-2009, 06:52 PM   #49 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
The glaciers have receded from the frozen steppes.
I am back up to 100 psi.
The truck coasts well again.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 04-02-2009, 10:57 PM   #50 (permalink)
high school
ModelE's Avatar
sabre - '02 Buick LeSabre Custom
90 day: 23.45 mpg (US)
frontier - '04 Nissan Frontier XE
90 day: 18.97 mpg (US)
i run 44-48 in my tires, which are cooper A/T s rated at 38 or 40
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
Tires with different max PSI Goldenfrog EcoModding Central 2 06-14-2008 03:42 PM
I upped the PSI to my tires from 29 to 35 and... MartialArtist EcoModding Central 55 04-04-2008 01:20 AM
