Old 03-15-2009, 09:58 AM   #11 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
44psi in the tires, 44psi sidewall max.
Nissan Versa Aeromods
Old 03-15-2009, 10:50 AM   #12 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
I'm running 50 psi on all four corners of the xD, brand new tires too ...
I didn't realize the sidewall stated max psi as 51. (Use to seeing 44psi)
Also dam dealer had the tires filled to 28psi, no wonder they try and scam you into tires for life with them ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 03-15-2009, 12:47 PM   #13 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
During snow season (December to end of March), I used the max on the sidewalls - 80 psi
During the rest of the year, I air 'em up to 100 psi. This does not 'crown' E-rated tires.
BTW, I get more than 100,000 miles out of a set of tires doing this.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 03-15-2009, 01:08 PM   #14 (permalink)
Yup, 80psi here on the truck too.....too bad they don't make e-rated tires for small cars, then y'all could see how rough the ride is at that tire pressure
1989 Dodge Diesel 972rwhp, 27mpg.
1971 Nova tubbed, solid cam 355 w/nitrous, 8mpg (sorry).
1960 Nash DIY Hybrid Project
Old 03-15-2009, 01:09 PM   #15 (permalink)
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
35 psi in winter, but now 40 psi with max sidewall of 44. Kumo Solus KH15.
Old 03-15-2009, 01:10 PM   #16 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I keep my wife's tires at max sidewall (44 psi summer/35 winter). I run 60 psi year round on my 35 psi max sidewall winters and 44 psi all seasons.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 03-15-2009, 02:21 PM   #17 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
I've got 35psi rated all-seasons, Don't remember what brand. The book says to set them at 33psi so I pushed then up to 40psi. I see a big change in how far it will coast just going from the 35 to 40psi. But you can definitely tell the difference in ride with the stiff suspension the Jeeps have.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 03-15-2009, 02:23 PM   #18 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
tasdrouille-
Have you ever had a problem running at 60 PSI? I'm considering running 55 or 60 in my tires. I bet the ride in the city would be hell, but 95% of my driving is highway, so I wouldn't mind.
Old 03-15-2009, 02:23 PM   #19 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by bwilson4web View Post
I'm a little confused by the question:
  • absolute pressure - I'm running Sumitomo T4s with 51 psi front and 49 psi rear.
  • relative pressure - My Sumitomo T4s are rated at maximum sidewall pressure of 51 psi so my relative pressure is 0 psi front and -2 psi rear.
  • OEM pressure - Toyota recommends 32 psi for OEM tires that came with my 2003 Prius so my replacement Sumitomo T4s are running +19 psi front and +17 psi rear.
Let me suggest that one or more polls might be a more efficient way to collect the tire pressure spread. Of all metrics, I would be more interested in the 'relative pressure' compared to the maximum sidewall pressure value. But given non-USA folks use standard units, a relative percentage might be more useful and easier to deal with.
It is a good question.
Bob Wilson
You brought up an interesting point:
Some drivers want to compare tire pressure to the manufacturer's recommendation.
Others want to compare to the tire's sidewall max.
That depends on whether they (or you) think that one or either of those is an authority you want to place your trust in.
Further, the tire sidewall imprint is often much higher than the mfg. recommend. If the car came with 35 or 44 psi tires, you can buy 51 or 60 psi tires - then what's your preferred pressure? Mfg's recommendation will of course stay the same; they're saying that's what's best for the vehicle.
I'm not saying that I'd follow either. I'm running 50 psi in 44 psi tires and not scared. YMMV, as usual.
Coast long and prosper.
Old 03-15-2009, 02:25 PM   #20 (permalink)
Big Dave-
What model of tires do you run? Our '99 F-350 Diesel (basically just for snow plow duty) has some Michelins, which spec for like 70-80 psi, I think.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
Tires with different max PSI Goldenfrog EcoModding Central 2 06-14-2008 03:42 PM
I upped the PSI to my tires from 29 to 35 and... MartialArtist EcoModding Central 55 04-04-2008 01:20 AM
