08-23-2012, 04:21 PM
#21 (permalink)
Then, I quote myself :
See attached image for details
Originally Posted by euromodder
would give this :
The key is to keep the text parts with the appropriate image tags, that are quoted as text while you're still in the editor.
08-24-2012, 12:52 AM
#22 (permalink)
So I'm hearing that the EM website as such doesn't cache any images but always refers to the source, e.g., dropbox. I suspect that is different to/from the Profile pix.
I take 'in the editor' as the Message input form. Using Mac OSX 10.6.8 and Seamonkey 2.11; I select and copy as such:
click the Quote button and Paste
and I can already see the picture isn't going to display.
08-24-2012, 10:17 AM
#23 (permalink)
S
I'm seeing both image-links that you included.
08-24-2012, 08:36 PM
#24 (permalink)
With all respect, did you see that the first image shows the image selected, and in the second there are 3 Returns where the link should be?
08-26-2012, 01:13 PM
#25 (permalink)
Quoted once - and the links remain in place and working
08-26-2012, 01:17 PM
#26 (permalink)
Quote once
Above answer quoted again - yes, in full.
As per forum software, you don't get quotes - or links / images - included in a reply when they are 2 quotation levels deep.
Maybe that was the issue ?
The Following User Says Thank You to euromodder For This Useful Post:
08-26-2012, 09:14 PM
#27 (permalink)
Well... thanks for your consideration.
I see no clickable links within your post #25. What I'm going to say at this point is the rest of my life is approximately this difficult, so maybe it's Karma. I will proceed by manually downing, upping it to Imgur and then Linking inside the Quote.
This is helpful. The more you know...
02-14-2015, 11:26 PM
#28 (permalink)
Belong to couple others sites that allow direct post of pics from local hard drive, very easy
02-15-2015, 12:44 AM
#29 (permalink)
As it is with this one, by visiting your User Control Panel and clicking Pictures & Albums. I was pretty much a noob in 2012 and don't use Imgur much anymore.
Also... welcome to EM.
02-15-2015, 07:31 PM
#30 (permalink)
Can you show the pic in the body or is it always a thumbnail? Apologies for asking noob questions freebeard
The Following User Says Thank You to isetta For This Useful Post:
