Old 10-08-2021, 05:19 PM   #231 (permalink)
Originally Posted by Isaac Zachary View Post
same emissions problems found in diesel engines
An increase to NOx emissions is still often pointed out as easier to mitigate on a gasser fitted with direct injection than on a Diesel, yet the PM is a real PITA for both. OTOH a gaseous fuel injected at the vapour phase, such as natural gas, won't be so troublesome regarding PM.
Old 10-08-2021, 06:28 PM   #232 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
That's because the gasser can be run at a stoichiometric AFR and a still very homogenous charge. Yet direct injection with spark ignition lends itself to a lean burning engine with a stratified charge. But it seems most, if not all OEMs are going with the former and not the later in their direct injection engine designs.
Old 10-09-2021, 12:19 PM   #233 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
PM has the same solution for gas and diesel - particulate filters. Natural Gas has the benefit of not requiring a particulate filter but the downside of needing super expensive fuel tanks that cost way more than a PM filter.
Old 10-10-2021, 07:02 PM   #234 (permalink)
Which could be avoided on gassers had direct injection not been so increasingly common on them.
Sure for an OEM it's easier to fit a particulate filter than working around a car to make it dedicated-CNG, and even some newer CNG-capable models available in Europe nowadays might retain a particulate filter as they retain the ability to run on gasoline. But the cost of CNG tanks has not been so much of an issue rendering conversions unsuitable in third-world countries.
Old 10-10-2021, 11:36 PM   #235 (permalink)
JSH
AKA - Jason
JSH's Avatar
Direct injection is required for emissions, performance and fuel economy. You get much better control injecting directly into the cylinder then the intake manifold. If direct injection wasn't a benefit OEMs wouldn't spend the extra money to fit it.
I'm specifically talking about OEM solutions where companies have to follow the law or face huge fines.
Old 10-13-2021, 05:13 PM   #236 (permalink)
Yet sometimes an "outdated" port-injection engine, even though not likely to outperform a counterpart fitted with direct injection, may actually result in a higher fuel economy and lower NOx emissions. Performance-wise, McLaren and Koenigsegg have been doing a great job with port-injection while most of the competition switched to direct injection.
Direct injection has its advantages, yet port-injection remains cost-effective for some applications.
Had either that Freevalve system or something analogue been widespread, it would be the end of direct injection on gassers. And even for flexfuels, there are easily-implemented cold starting aids.
Old 09-13-2023, 01:13 PM   #237 (permalink)
Old 09-13-2023, 02:38 PM   #238 (permalink)
Excluded 2023 so they don't have to include Californica?
hurricane, vitriolic tesla hate
