06-30-2020, 02:59 PM
AKA - Jason
Hyllion ERX - A Natural Gas Hybrid Electric Semi
This is Hyliion's new hybrid system. It is an electric truck with a natural gas powered generator to charge the battery. It can run EV only for 25 miles to enter EV only areas in cities and cruise 1,300 mile on a tank.
This is a great idea for a realistic way to transition long-haul trucking to alternative fuels. Natural gas stations already exist and NG trucks have very low emissions. It is likely actually simpler than a modern diesel truck with all the emission controls and little fuel economy tweeks.
https://www.hyliion.com/erx-page/#/performance
The Following 2 Users Say Thank You to JSH For This Useful Post:
07-04-2020, 08:14 AM
Amazing it can hold enough CNG to run 1300 miles working a load. Or can it?
07-04-2020, 10:21 AM
Using 6mpg, you need 216 gallons of diesel so perhaps 1000 gallon high pressure gas. The tanks shown look almost big enough for1/2 that, one on each side.
The CNG transit vans I drove had a 50 gallon tank where the gasoline tank was but I could only get maybe 60 miles out of it before refill. Some days I refilled 3 times.
07-05-2020, 10:17 PM
Do you remember how many GGEs it could hold?
07-06-2020, 06:43 AM
AKA - Jason
It has a side tank on each side and a giant cabinet tank behind the cab.
Also as a hybrid it should be more efficient than CNG converted diesel.
EDIT: I believe the 1300 mile range is for liquid natural gas which is about 4x denser than compressed natural gas.
07-06-2020, 09:34 AM
The outfit I worked for was hugely non technical, so, unfortunately no. They had issues scheduling how far I could run before refueling even after I gave them a tank range.
Liquid gas is comparable to gasoline for BTU content, so if that's the case 1300 miles is much easier.
07-06-2020, 11:31 AM
I wonder what happened to that one guy who was on a mission to improve MPGs on a huge fleet? He kept going on and on about HHO, insisting that testing proved a benefit.
07-07-2020, 12:27 PM
AKA - Jason
Some more detail now that I have access to a computer:
Agility LNG side tanks are up to 160 DGE each
Agility CNG side tanks are up to 60 DGE each
Agility CNG Cabinet tanks are up to 175 DGE
07-07-2020, 05:38 PM
#9 (permalink)
What is a DGE? Distance per Gallon Equivalent?
07-07-2020, 08:44 PM
#10 (permalink)
Thalmaturge
Diesel gallon equivalent
The Following User Says Thank You to samwichse For This Useful Post:
