Old 07-11-2020, 05:23 PM   #21 (permalink)
CNG trucks are also signifigantly heavier than diesel trucks with similar range.
That's one reason why I consider it more viable to use CNG on urban transit buses than in heavy trucks. Garbage trucks might be a good case for CNG as long as they can resort to biomethane extracted from the landfills.
Old 07-12-2020, 02:11 PM   #22 (permalink)
90 day: 29.78 mpg (US)
Garbage trucks should be battery powered by now. Short distances, high torque needed, constant starts/stops. Absolutely perfect job for a battery/electric drivetrain.
JSH (07-12-2020)
Old 07-12-2020, 11:34 PM   #23 (permalink)
But almost all municipalities want to buy the cheapest price garbage truck they can get, since it's just a garbage truck. No one cares if the garbage trucks are nice.
Old 07-13-2020, 04:00 AM   #24 (permalink)
Emission regulations are helping to speed that transition as NG trucks burn clean enough to avoid urea injection and particulate filters. They are as simple as pre-emission diesels.
Particulate filters yes, urea injection no. Excess air is mandatory at low load for compression ignition, making the urea injection necessary.
Old 07-13-2020, 09:41 AM   #25 (permalink)
Most of the munis I am associated with subcontract to Waste Management or one of their affiliates which are not noted for their concerns about anything but profit
Old 07-13-2020, 08:07 PM   #26 (permalink)
Natural gas avoids both, even if a dedicated-CNG engine would rely on direct injection.
Old 07-13-2020, 10:55 PM   #27 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Dedicated CNG engines like the Cummins L9N are spark ignition.
https://freightlinerads.azureedge.ne...2019-05-31.pdf
CUMMINS ® WESTPORT L9N 8.9 LITER NATURAL GAS ENGINE
• Uses stoichiometrically-cooled EGR combustion
• EPA 2017 and CARB emissions standards compliant
• Available up to 320 HP, 1000 lb-ft torque
• No SCR aftertreatment system required
• Maintenance-free exhaust system
• No DPF regeneration, cleaning or replacement
• Spark-ignited
• Dedicated natural gas engine – no dual fuel
The Following User Says Thank You to JSH For This Useful Post:
samwichse (07-14-2020)
Old 07-14-2020, 03:50 PM   #28 (permalink)
Now that Scania is partnering with Cummins, it would be interesting if they tried ethanol in a spark-ignited engine initially developed for CNG. Might work better than the failed compression-ignition ethanol engines which required an ignition improver to be blended into the ethanol, plus it could allow a much useful limp-home mode once CNG is depleted. This could eventually be a good option for agribusiness in Brazil.
