06-06-2010, 11:57 PM
#31 (permalink)
Metro HotRodder
Nitogen in the tires as in a Airplane, they also do that in Racecar tires ,it keeps the pressure the same even when the tires and inside air in them gets warmed up .
Im wondering about the "donut spare" the small spare tires that say Dont go over 45 on the side and they are good for 60 PSI , has anyone ever ran a set of 4 of these and seem how they handle and what kind of gas mileage improvment they provide? I have 5 or 6 15" donut spares I would like to try out but would like to hear some real life experiance with them Scott
06-07-2010, 12:12 AM
#32 (permalink)
They have about 2500 miles on them, installed a month and a half ago.
There's also 2 inward bubbles on my spare. Only ran 50 miles on it, and it's still at the original 35 PSI.
In Reason we Trust
06-07-2010, 08:22 AM
#33 (permalink)
Camry MPG Modder
Curious what brand they were so we all can keep that in mind when hyper-inflating
Sorry to hear this happened on your new set of tires.
Well at 2500 miles I would hope you can get them replaced as defective.
Bought my Yokohama's from discount tire direct and right about now I am going to find and fill out that tire registration card I never sent in.
Also going to check my pressure a couple of hrs into my next long trip to confirm the warm/hot tire pressure.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
06-07-2010, 10:00 AM
#34 (permalink)
Pokémoderator
AeroModder -
Can you post some pictures (does the black rubber make it hard to see)?
CarloSW2
06-07-2010, 10:55 AM
#35 (permalink)
They're very hard to see, and I really only found them by feel. I'll see what I can do, though.
In Reason we Trust
06-07-2010, 11:00 AM
#36 (permalink)
Originally Posted by VegasDude
Don't forget about Nitrogen. They use it in airplanes. That means you really need it.
hahaaha I wonder what we're putting in our tires anyway...I typically fill with about 75% nitrogen, 19% oxygen, plus a little water vapor, argon, and some other trace gases - helps the tires warm up faster that way - they're a bit flatter for the first 1/2 mile, then the tires warm up and the vapor expands, fully inflating the tires!
Don't get why anyone would pay for what we have about 80% of anyway.
06-07-2010, 11:03 AM
#37 (permalink)
Hypermiler
If they're inward dents, it could be where the sidewall belts are joined and overlapped, and not a problem. All 8 tires on my 2 vehicles have these - two depressions that run from the rim out to the tread (like spokes), about 6 inches apart from each other.
Outward bulges are bad.
http://www.tirerack.com/tires/tirete....jsp?techid=32
06-07-2010, 11:40 AM
#39 (permalink)
Pokémoderator
PaleMelanesian -
Originally Posted by PaleMelanesian
I have the inward dents too. When I first saw this, I lowered the PSI, but they didn't go away, so I restored the PSI.
CarloSW2
06-07-2010, 11:45 AM
#40 (permalink)
Pokémoderator
AeroModder -
Ok, I have those too. I only noticed the inward ones, but I will look for the outward ones also. I think I have had them for the life of the tire, but I don't think I noticed them until maybe 10 or 20K miles. Because I already had so many miles on my tires, I (crossed my fingers and) didn't worry about them. I now have 60K miles on my tires. I will also post a picture when I get a chance.
I will also go looking at my wife's and other people's tires while I am at it.
CarloSW2
