Old 06-06-2010, 11:57 PM   #31 (permalink)
sjr
Metro HotRodder
Nitogen in the tires as in a Airplane, they also do that in Racecar tires ,it keeps the pressure the same even when the tires and inside air in them gets warmed up .
Im wondering about the "donut spare" the small spare tires that say Dont go over 45 on the side and they are good for 60 PSI , has anyone ever ran a set of 4 of these and seem how they handle and what kind of gas mileage improvment they provide? I have 5 or 6 15" donut spares I would like to try out but would like to hear some real life experiance with them Scott
Old 06-07-2010, 12:12 AM   #32 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
They have about 2500 miles on them, installed a month and a half ago.
There's also 2 inward bubbles on my spare. Only ran 50 miles on it, and it's still at the original 35 PSI.
In Reason we Trust
Old 06-07-2010, 08:22 AM   #33 (permalink)
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
Curious what brand they were so we all can keep that in mind when hyper-inflating
Sorry to hear this happened on your new set of tires.
Well at 2500 miles I would hope you can get them replaced as defective.
Bought my Yokohama's from discount tire direct and right about now I am going to find and fill out that tire registration card I never sent in.
Also going to check my pressure a couple of hrs into my next long trip to confirm the warm/hot tire pressure.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
Old 06-07-2010, 10:00 AM   #34 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
AeroModder -
Can you post some pictures (does the black rubber make it hard to see)?
CarloSW2
American Solar Energy Society
Old 06-07-2010, 10:55 AM   #35 (permalink)
AeroModder's Avatar
Team Ford
They're very hard to see, and I really only found them by feel. I'll see what I can do, though.
In Reason we Trust
Old 06-07-2010, 11:00 AM   #36 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Originally Posted by VegasDude View Post
Don't forget about Nitrogen. They use it in airplanes. That means you really need it.
hahaaha I wonder what we're putting in our tires anyway...I typically fill with about 75% nitrogen, 19% oxygen, plus a little water vapor, argon, and some other trace gases - helps the tires warm up faster that way - they're a bit flatter for the first 1/2 mile, then the tires warm up and the vapor expands, fully inflating the tires!
Don't get why anyone would pay for what we have about 80% of anyway.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 06-07-2010, 11:03 AM   #37 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
If they're inward dents, it could be where the sidewall belts are joined and overlapped, and not a problem. All 8 tires on my 2 vehicles have these - two depressions that run from the rim out to the tread (like spokes), about 6 inches apart from each other.
Outward bulges are bad.
http://www.tirerack.com/tires/tirete....jsp?techid=32
Old 06-07-2010, 11:18 AM   #38 (permalink)
AeroModder's Avatar
Team Ford
Some are inward, but there are a few outward ones:
http://i3.photobucket.com/albums/y93...ey/tire005.jpg
http://i3.photobucket.com/albums/y93...ey/tire006.jpg
After reading the link, these are definitely defective. The cords are very poorly lined.
In Reason we Trust
The Following User Says Thank You to AeroModder For This Useful Post:
cfg83 (06-07-2010)
Old 06-07-2010, 11:40 AM   #39 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
PaleMelanesian -
Tire Tech Information - Sidewall Indentations, Undulations and Protrusions
I have the inward dents too. When I first saw this, I lowered the PSI, but they didn't go away, so I restored the PSI.
CarloSW2
Old 06-07-2010, 11:45 AM   #40 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
AeroModder -
Ok, I have those too. I only noticed the inward ones, but I will look for the outward ones also. I think I have had them for the life of the tire, but I don't think I noticed them until maybe 10 or 20K miles. Because I already had so many miles on my tires, I (crossed my fingers and) didn't worry about them. I now have 60K miles on my tires. I will also post a picture when I get a chance.
I will also go looking at my wife's and other people's tires while I am at it.
CarloSW2
Geo Metro High-Speed chase bennelson The Lounge 17 06-18-2010 08:39 AM
Integra owners, need input regarding fuel cut greasemonkee Off-Topic Tech 3 01-22-2010 11:12 PM
"Pulse and DFCO" (deceleration fuel cut off) doesn't work MetroMPG Hypermiling / EcoDriver's Ed 16 08-28-2009 07:58 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
ScanGaugeII Throttle Cut Off and MPG Calibration ballegre Instrumentation 9 07-18-2008 02:46 PM
