Old 12-06-2011, 04:34 PM   #31 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
Originally Posted by Gone View Post
Facts are a hard reality.
83 2011 Elantra owners have filled up their cars 2095 times, have driven 618,714 miles, are averaging 30.7 mpg, thought they'd get something from 29/33/40, and apparently, based on the OP, are unhappy. (Hyundai Elantra MPG Reports | Fuelly)
A hard reality indeed.
Guess they think being in an econo box allows them to flat foot it all the time...
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 02-06-2012, 01:09 PM   #32 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
FYI, Pop Mechanics recently ran a fuel economy test using the Elantra (and Ford Focus). You can decide for yourself how valid their test method was (described in the article).
They found that their Elantra was good for 47.6 mpg (US) @ 55 mph and 39.3 mpg (US) @ 70 mph on their highway run. In their city loop, they measured 34.1 mpg (US).
Recall city/hwy EPA ratings for the car are 29 / 40 mpg (US).
Source: Mileage Moment of Truth - We Put 40 Mpg Claims to the Test - Popular Mechanics
Old 02-06-2012, 02:11 PM   #33 (permalink)
As the manufacturers extract better mileage out of their designs, it will become much more difficult to beat EPA figures by a significant margin without significantly lowering your average speed.
The wife's Kia Sorento with the GDI 2.4 is averaging about 26 on her local stop and go driving. It's rated at 32 highway. Her previous car, an 09 Nissan Rogue, was rated at 27 highway. She regularly averaged 28 MPG in the Rogue driving basically the same routes over the years and tens of thousands of miles.
The Sorento weighs 3800 pounds, about the same as a Murano, while the Rogue was about 500 pounds lighter.
Best ever mileage for me in her Rogue was 33 MPG. I haven't driven a back roads 55 MPH average trip in the Sorento, but I would bet the mileage would be about the same.
I have seen over 32 on the Interstate and we recently removed the roof rack cross braces. In traffic I have seen 35 MPG, exceptional mileage from a 3800# CUV. Not overall for a trip but for 15 miles.
Bottom line, it was easy for her to beat highway EPA in her local driving in the Rogue. Best I have ever done with the Sorento is about 29 MPG on a local route drive, which is just about the same as I would have done in the Rogue.
I think cold weather (and we have nothing but E10 here) have a more significant effect on the direct injection engine mileage, both the E10 and the cold weather. It will be interesting to see what happens in warmer weather, and the EPA should stop using E0 in any testing since it is getting to the point where that fuel is no longer available in most of the parts of the country anymore.
regards
Mech
Old 02-06-2012, 02:44 PM   #34 (permalink)
The reason they're squeezing such good MPG numbers out of all these new cars is because they're using the VVT to run the atkinson cycle at part load. They're able to switch back and forth between atkinson and otto cycle very quickly so the driver never notices a loss in throttle response and torque. Even the mustang is using this trick.
Old 02-06-2012, 03:29 PM   #35 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
tjts1 -
That's a cool detail to know. I will look for this detail in the literature.
CarloSW2
American Solar Energy Society
Old 02-06-2012, 03:43 PM   #36 (permalink)
Originally Posted by cfg83 View Post
tjts1 -
CarloSW2
It didn't even occur to me until I read it in a Mustang article.
The Duratec 3.7 V-6 is actually what the engineers call a "mild Atkinson-cycle" engine, where the variable intake valve mechanism keeps the intake valve open much longer than in a standard engine for better mixing in the chamber, thus reduced pumping work and better fuel economy.
Read more: 2011 Ford Mustang 3.7L V6 Engine - Muscle Mustangs & Fast Fords
"Mild Atkinson cycle"
First, the vehicle uses what he calls "mild Atkinson Cycle" combustion, which simulates a compression stroke that's shorter than the power stroke by leaving valves open during part of that stroke. This slightly reduces the power needed to pump air, improving its efficiency.
The Atkinson Cycle engines fitted to full hybrids run very efficiently at high speeds, at the cost of producing very little torque at low speeds. The hybrid's electric motor, which produces maximum torque from 0 rpm, neatly complements this.
Without an electric motor, the 2011 Explorer's engine can't run a full Atkinson cycle, but even shaving fractions from its pumping losses raises the power it generates from the gasoline it burns.
http://www.greencarreports.com/news/...id-tech-tricks
Old 02-06-2012, 05:40 PM   #37 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
We got a 2012 AT Elantra. Drove it 2300 miles all highway from Louisiana to California. First 1200 miles at the PSL (as high as 80 mph in west TX), averaged just ~36 mpg.
Last 1100 miles I aired the tires up to 51 psi and drove between 60 and 65 mph, and averaged something like 44.7 mpg.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 11-02-2012, 10:55 AM   #38 (permalink)
Hyundai/Kia MPG claims busted by EPA
Hyundai admits their ratings were inflated by 2-3 MPG after an investigation by the EPA.
Hyundai aggressively advertised the fact that the brand offers four models that boast 40 mpg [highway], but that claim is no longer true. The 2013 Hyundai Accent, Veloster and Elantra will now see their EPA estimates fall to either 37 or 38 miles per gallon on the highway.
The company blamed it on "procedural errors" and will compensate owners.
Hyundai, Kia admit exaggerated mileage claims, will compensate owners
See also: Detroit News - http://www.detroitnews.com/article/2...372/1148/rss25
EPA press release: http://yosemite.epa.gov/opa/admpress...d?OpenDocument
EPA had received a number of consumer complaints about Hyundai mileage estimates. Through the agency’s ongoing audit program, staff experts at EPA’s NVFEL observed discrepancies between results from EPA testing of a MY2012 Hyundai Elantra and information provided to EPA by Hyundai.
EPA’s audit testing occasionally uncovers individual vehicles whose label values are incorrect and requires that the manufacturer re-label the vehicle. This has happened twice since 2000. This is the first time where a large number of vehicles from the same manufacturer have deviated so significantly.
Old 11-02-2012, 11:16 AM   #39 (permalink)
"Procedural errors" sure... I wonder how many sales this 'error' netted them.
Old 11-02-2012, 11:28 AM   #40 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I just saw this EPA report in today's LATimes, but I gotta say, the Sonata I rented last summer in PA was remarkable in 6th gear, down around 1700/1800 RPMs at 60mph, IIRC. The Elantra auto trnas also has that gearing. I'll try to talk my wife out of her 2010 Subaru Forester and into one of these in a year or two, when she can get a dealer-certified used one with much of its heaviest depreciation already complete.
