Old 02-19-2019, 12:20 PM   #41 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Here's a weight saving mod you can try -- I recently did this to my G1 Insight:
https://www.insightcentral.net/forum...v-battery.html
I've saved 20 pounds by removing the lead-acid 12v and replacing it with two Insight IMA battery sticks.
IDK if they will crank the starter, but I think they might be able to.
The Following User Says Thank You to Natalya For This Useful Post:
Gasoline Fumes (02-20-2019)
Old 02-21-2019, 05:25 PM   #42 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I wouldn't want to rely on the battery sticks for cranking an engine, even if they could do it. I also do a lot of EOC at night, which is hard on batteries. I have two massive deep-cycle batteries in my Civic, which give me over 100 miles of driving with the alternator off. I really want to come up with a lighter battery setup for the Insight, but I don't think the NiMH sticks will be enough. I could try using more sticks, but I don't know how many (if any) good sticks I have.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 02-21-2019, 05:48 PM   #43 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I have a 20Ah LiFePO4 battery in mine along with supercaps. I've (accidentally) driven to work without turning on my DC-DC converter a few times. It's only about 10 miles / 20 minutes but I was very easily able to make the drive with the stereo + sub blasting, rear defroster, headlights, and climate control running, and only use ~20% of the capacity available. The batteries are much safer than LIon and weigh ~6.6lbs.
https://www.batteryspace.com/lifepo4...assed-dgr.aspx
I'd advise pairing them with capacitors on days below freezing, but YMMV. As long as you're gentle on them they may be ok.
Gasoline Fumes (02-21-2019)
Old 04-13-2019, 11:17 PM   #44 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
#2
So I just got a second 2000 Insight in Silverstone Metallic. Recent catalytic converters and IMA battery from a Honda dealer. I need to build a grid charger and see if the battery will recover after sitting for a couple of years. I disabled the IMA before starting it up. Runs great! No mice in this one! Neither Insight came with keys, I had to drop the steering column on both to get them home. No, I'm not stealing Insights!
I might be a car hoarder.
ID:	25762   Click image for larger version
ID:	25763   Click image for larger version
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Ecky (04-14-2019)
Old 04-14-2019, 12:51 AM   #45 (permalink)
90 day: 51.82 mpg (US)
Might be?
Gasoline Fumes (04-14-2019)
