Old 05-09-2012, 10:16 PM   #21 (permalink)
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
Originally Posted by Gasoline Fumes View Post
... I can't use ramps...
You certainly can use ramps!
Not only are there low-angle ramps available commercially (here's just one example), you can make your own.
I got a 2x10"x12' board, cut it in half, then into 2' and 4' sections. Bevel one end of each section (at a shallow angle so your tire doesn't just push the ramp) and stack them using wood screws. Now you have a pair of low, wide, stepped ramps. If my lowered BMW with an air dam can get up on these, your Honda certainly can.
The Following 3 Users Say Thank You to Shawn D. For This Useful Post:
aerohead (05-10-2012), Gasoline Fumes (05-11-2012), seifrob (05-11-2012)
Old 05-11-2012, 11:27 AM   #22 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Effectiveness depends on how you pronounce "decals" though.
Deekals or deckuls for better MPG?
Thanks either way! My rear windows are so small that I had to separate the logo.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 05-11-2012, 11:47 AM   #23 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Thanks. There's really just one speed bump I'm concerned about. I actually parked over it and measured the clearance before making the skirts. I think it should just barely clear if I go over it really slow. I will stop over it and see how close the skirts are.
I got a chance to check the infamous speed bump. The skirts clear it by an inch.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 05-12-2012, 09:23 PM   #24 (permalink)
TBD - '17 Toyota Corolla LE
90 day: 40.79 mpg (US)
Starship - '08 Toyota Prius
90 day: 42.34 mpg (US)
Mine are 7" tall. I don't know what's ideal, I just don't think I can get away with them being any lower. I'm concerned about them scraping on speed bumps at their current size. My front air dam scrapes and it's about the same height. But it's a lot tougher than coroplast.
Can you tell me the height from the bottom of the skirt to the ground? Considering side skirts and trying to determine roughly how deep I should make them.
Oh, and what MPG gain have you seen?
Old 05-14-2012, 10:05 PM   #25 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
They are about 6" above the ground.
I don't have an accurate way to measure MPG gains of individual mods.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 05-15-2012, 05:58 AM   #26 (permalink)
Thanks. Do you have a feel if the side skirts in particular helped MPG?
Old 05-15-2012, 01:06 PM   #27 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I don't know yet if they help. I should try some coast-down tests. It's hard to even get an accurate tank MPG test of the skirts. I get my best mileage driving at 40 MPH and below, the skirts probably don't help a lot at those speeds.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 09-24-2013, 11:17 PM   #28 (permalink)
AERO-CRX in the Works
A fellow Civic Wagon Owner(s)!
Ya, I know it's an old thread... But still happy to see them on here.
