Old 10-01-2020, 07:23 PM   #21 (permalink)
Originally Posted by JulianEdgar View Post
And you've got the mechanical and electronics background to do that? Turbo selection; fabrication of the exhaust manifold, intake plumbing, intercooler plumbing; development of engine management, changing the fuel system and injectors - and so on?
Maybe I am pretty slow, but just turbocharging my Insight and fitting and mapping the engine management was, for me, a year-long project on its own.
And I have done turbo and electronics work on cars plenty of times before!
It won't necessarily be turbocharged, gasoline, nor EFI. My previous project was a propane turbo (non-EFI) 2.3 L Ford in a '61 Comet.
The Following User Says Thank You to sgtlethargic For This Useful Post:
freebeard (10-01-2020)
Old 10-01-2020, 07:26 PM   #22 (permalink)
Thanks for not getting half done before asking for opinions.
Personally, I'd be most comfortable with a Beetle floorpan.
I know you like Bugs. If my brother would kick down the free Karmann Ghia he got 30 years ago ...
Old 10-01-2020, 07:30 PM   #23 (permalink)
They're modular. My son gave away the Ghia I bought for him when he needed a car [in 2012].
But, '61 Comet?
Old 10-01-2020, 07:31 PM   #24 (permalink)
Great!
(It was just that you said you wanted 'an efficient engine operating at its peak' and to get that, engine management is obligatory.)
Old 10-02-2020, 04:42 AM   #25 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
And I want it to look vintage.
100 mpg at 60 mph. What do you think it would take to accomplish this? Single-seater, center-steer, possibly mid-engine, probably a 4-cylinder.
I love the looks of the BOCruiser. And the Phantom Corsair. Hudson Hornets. This custom Metropolitan (they weigh 1750 pounds).
this
do forget to knit your self some seatbelts
Old 10-02-2020, 10:23 AM   #26 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
As mpg_numbers_guy said earlier, the Insight is a great point of reference. In stock form, using exreme LRR tires which sacrifice handling and traction, with the inflation pressure raised to 45+, and a few minor aero mods (partial grille block), the Insight is capable of 100mpg @ 50mph. As speed increases, that fuel economy drops significantly. I want to say that at 60mph, it's closer to 80mpg.
https://ecomodder.com/wiki/Vehicle_C...t_of_Drag_List
The Insight has a 0.25 drag coefficient (very low), a frontal area of ~20 sq ft (very low), and an engine whose peak thermal efficiency is just as good as the best from Toyota and Honda today (~40%) - albeit with a lower output than Toyota and Honda's current best.
My thinking is, you'll need an engine that is no less efficient than the Insight's, which is a very short list. You will also need to beat it in both coefficient of drag and frontal area. Diesel helps - the fuel contains ~15% more energy content, but you also usually pay more for it so it may not win in cost per mile.
If the goal is cost per mile per unit energy, going electric in an area with cheap electricity may be the easiest way to achieve this, but you have the upfront costs of the batteries.
From the Urban Centurion thread,
Originally Posted by changzuki
The original Centurion reported 128mpg@35mph.
^ While that's impressive, drag increases with the square of the speed. Using a simple drag calculator, the drag at 60mph is 3x higher than at 35mph, while the speed has only increased by 70%. Meaning that, if drag is the sole difference between MPG at the two speeds (RR and mechanical loss stay constant), that 128mpg @ 35mph might be 75mpg @ 60mph. Still very respectable, but the decently aerodynamic Centurion with its 37hp-at-the-flywheel engine is still well short of your target.
COcyclist (10-27-2020)
Old 10-02-2020, 11:02 AM   #27 (permalink)
Originally Posted by Tahoe_Hybrid View Post
this
Is there hostility in this reply?
Old 10-02-2020, 11:49 AM   #28 (permalink)
Many 'do' was a typo and it's just incoherent otherwise?
Old 10-02-2020, 12:49 PM   #29 (permalink)
100-mpg @ 60
See if you can find Doug Malewicki's 'California Commuter, or Alex Tremulis' Subaru X-100, both of the 1980s.
I abandoned my project simply considering how traffic behaved around me when on a motorcycle.
Americans are sociopaths by default. They won't follow at a safe distance and going up against a 3.5-ton projectile is more than I want to contemplate.
The guy who bought Three-Wheeler's 1st-gen Insight boat-tail is routinely seeing 80-mpg on the open road. And it's 5-star safety rated.
Pay attention to Julian's wisdom on this one! I've already lost a brother to an SUV. I don't want to hear about you.
Ecky (10-02-2020)
Old 10-02-2020, 02:09 PM   #30 (permalink)
That's a nice thought.
Build to pass a tech inspection at some race track, SCCA, NHRA, 24 Hrs of Lemons, etc.
aerohead (10-02-2020)
