Old 07-20-2018, 04:02 PM   #171 (permalink)
I made up a mirror blocking plate for my Mirage the other day. Still tweaking it a little bit.
The Following 7 Users Say Thank You to Daox For This Useful Post:
freebeard (07-20-2018), NeilBlanchard (07-24-2018), niky (07-24-2018), RedDevil (07-21-2018), UltArc (07-21-2018), Vekke (05-24-2023), Xist (07-20-2018)
Old 07-20-2018, 05:41 PM   #172 (permalink)
Why did you choose those angles instead of trying to match the other piece of trim?
Old 07-21-2018, 11:07 AM   #173 (permalink)
The OEM piece actually has a chamfered edge. My piece is flat. Its simply the outer profile as the 3d printer prints it from the outside in. You're seeing the pattern the 3d printer took as it made the piece.
The Following 2 Users Say Thank You to Daox For This Useful Post:
Fat Charlie (07-22-2018), NeilBlanchard (07-24-2018)
Old 07-21-2018, 01:50 PM   #174 (permalink)
90 day: 51.82 mpg (US)
I think the angles made by the print head give the part a 3-D look in the pic that isn't really there.
Old 07-21-2018, 02:02 PM   #175 (permalink)
I am looking at the plastic grain?
Old 07-21-2018, 02:52 PM   #176 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
angle of the dangle. look at the 2nd pic and from the back it's clearly flat.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 07-21-2018, 04:36 PM   #177 (permalink)
It's like looking at a plowed field from altitude. But the question persists, why didn't you match the chamfer on the triangle attached to the body?
Old 07-21-2018, 05:09 PM   #178 (permalink)
I may add the chamfer on it later. For now, I just needed to see if it would fit up. Get it functioning first, then make it pretty later.
Old 07-22-2018, 12:38 AM   #179 (permalink)
Fail early, fail often.
Old 07-22-2018, 08:59 AM   #180 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
3D printers make things look 3D even when they're not. They're that good.
Transmission type Efficiency
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
MetroMPG (07-24-2018), Xist (07-22-2018)
