07-20-2018, 04:02 PM
#171 (permalink)
The Following 7 Users Say Thank You to Daox For This Useful Post:
07-20-2018, 05:41 PM
#172 (permalink)
Why did you choose those angles instead of trying to match the other piece of trim?
07-21-2018, 11:07 AM
#173 (permalink)
The OEM piece actually has a chamfered edge. My piece is flat. Its simply the outer profile as the 3d printer prints it from the outside in. You're seeing the pattern the 3d printer took as it made the piece.
The Following 2 Users Say Thank You to Daox For This Useful Post:
07-21-2018, 01:50 PM
#174 (permalink)
I think the angles made by the print head give the part a 3-D look in the pic that isn't really there.
07-21-2018, 02:02 PM
#175 (permalink)
I am looking at the plastic grain?
07-21-2018, 02:52 PM
#176 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
angle of the dangle. look at the 2nd pic and from the back it's clearly flat.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
07-21-2018, 04:36 PM
#177 (permalink)
It's like looking at a plowed field from altitude. But the question persists, why didn't you match the chamfer on the triangle attached to the body?
.Necessity is the mother of invention, but simplicity is it's favorite aunt --Amish proverb
07-21-2018, 05:09 PM
#178 (permalink)
I may add the chamfer on it later. For now, I just needed to see if it would fit up. Get it functioning first, then make it pretty later.
07-22-2018, 12:38 AM
#179 (permalink)
Fail early, fail often.
07-22-2018, 08:59 AM
#180 (permalink)
Rat Racer
3D printers make things look 3D even when they're not. They're that good.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
