Old 02-16-2012, 06:53 PM   #11 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
At first I was reminded of that exhaust heated intake side cat that reacts the gasoline upstream of being injected so it burns more completely.
Old 02-16-2012, 07:45 PM   #12 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
California98Civic -
Originally Posted by California98Civic View Post
I noticed the NOx omission too in some of their results too. On another part of the site, IIRC, they showed that their muffler has little or no benefit with that pollutant, I think. But they posted video (edited video) of a comparative test between just a CAT and the CAT plus their "EV8" ... it shows what it alleges are sceenshots of the toyota's emissions:
It may be that the NOx is not part of Australian emissions testing. We need to find out what their emissions laws are.
CarloSW2
American Solar Energy Society
Old 02-16-2012, 11:15 PM   #13 (permalink)
It's easy to see from the readout that the "After" runs have the engine running much leaner, which explains the lower HC and CO readings and the much higher O2 readings.
I'm not sure how a muffler would cause an engine to run leaner unless it drastically changed the O2 sensor readings... but yes, those numbers would indicate that NOx levels will be correspondingly higher. I'd like to see EGTs for that.
This is the first time I've heard of a hotter exhaust causing lean running instead of the other way around...
EDIT: Mazda uses exhaust pulse tuning to enable their SkyActiv engines to do ultra-lean burn... and I've seen really good flowing headers cause lean-running, but this is different, obviously, from a down-stream muffler that looks more restrictive than a straight through... I'd like to see if and how this creates pulses that enable better scavenging for myself before passing judgment.
The Following 2 Users Say Thank You to niky For This Useful Post:
California98Civic (02-17-2012), cfg83 (02-17-2012)
Old 02-17-2012, 12:19 AM   #14 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
I don't know about whether this applies universally, but if I reduce the back pressure on my car's exhaust, the engine will run leaner. I'm not sure of the exact reason, but it is something that tuners take into account.
Regardless, I'm sure that the NOx has to have increased significantly. If anything, these results look similar to the results I've seen for "high-flow" aftermarket CATs. Usually 100 to 300 cpsi (as opposed to the 600+ for OEM, ceramic CATs).
Old 02-17-2012, 01:29 AM   #15 (permalink)
But these are mufflers that go onto the exhaust of a car already running catless. Why would mufflers with inner (capillary?) tubes cause less backpressure? Is it because some resonance tuning causes better scavenging? Or is there something to the hot exhaust idea (supposedly hot enough to melt cats...)? And how does it heat up the exhaust?
Old 02-17-2012, 10:20 AM   #16 (permalink)
Team Emperor
I'm not sure why the mufflers themselves would lean out the AFR, but that seems to be the result. In regards to back pressure, most OEM mufflers are baffled and cause the exhaust to change direction (slowing it down and causing back pressure). These mufflers are a straight-through design, so the exhaust gasses should be faster and less impeded.
Old 02-17-2012, 10:37 AM   #17 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
I think what we are suspecting here is that the Emissions Fairy turned the mixture screw om the Camry between tests..
Old 02-17-2012, 12:55 PM   #18 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
jakobnev -
Hmmmm, good point. Is my table consistent with that hypothesis?
CarloSW2
Old 02-17-2012, 01:35 PM   #19 (permalink)
Eco-ventor
jakobnev's Avatar
House of Tudor
Team Mazda
Plug-in Hybrids
cfg83 -
The table screams it.
Old 02-17-2012, 02:13 PM   #20 (permalink)
EcoModding Lurcher
mort's Avatar
cfg83 -
At the start of the video a slide says "no tuning or modifications" I just don't see how any muffler can increase A/F from 15.1 to 17.1. At 17.1 that Toyota would have been barely able to keep running.
If I may speculate, there is an open fitting on the Vapouriser and by venturi effect, air is drawn into the exhaust system, diluting the emissions and adding oxygen some of which improves converter action. Many problems with this theory, like any back pressure...
More likely Emissions Fairy.
-mort
